Members: 19,778 | Total Threads: 40,092 | Total Posts: 471,088 Currently Active Users: 2055 (3 members and 2052 guests) Welcome to our newest member, nijhermouj |
#11 | |
With the engine off (having been run a few minutes)and the ignition lights on, the warning light should be off at first as the bomb has been pressured by the pump. You then pump the brake pedal. The light will come on when the pressure is lost in the bomb. If this is after 2-4 pumps, that's not good news for the bomb-but it might be that the pump is not pressurising the bomb. If it takes 25 pumps, the bomb is good, as is the pump. Starting the engine should pressurise the bomb quickly, and the light should go off. If it does not go off quickly, then the pump is faulty. If the light goes off quickly, it may be that the pump is pressuring the bomb but if the bomb is faulty then there is only a little pressure being held in it. But we will know from pumping the pedal if a lot of pressure is being stored in the bomb or not so combining these tests will point us to the problem. If the light goes off slowly, the pump is probably faulty regardless of the state of the bomb. The pump can be tested by rotating the pulley with the belt off, and feeling for two noticeably hard points in rotation. My bet is my light comes on after 2 pumps, that the bomb pressurises quickly after starting car, and that there is resistance when hand turning the pump. So the pump works, but there is not much pressure stored in the bomb (so the bomb need to be fixed). I am also checking that the injectors are not leaking when sat. Thus i do not want to repeatedly start the car until that test is done. And its raining. etc
2014 S3 (daily drive) 1987 MB ur Last edited by BackintheFold; 15-09-21 at 12:31 PM. |
#12 |
I ran the engine. No red light so pressure ok at this point.
Switched off. Red light immediately on. So, pump is fine but bomb is shot.
