Classic Audi » Classifieds section » Parts Wanted » Ur Quattro Accelerator Pedal linkage bush
Old 05-05-16, 12:08 AM   #1
Default Ur Quattro Accelerator Pedal linkage bush
Im after the bush that captures the accelerator cable under the passenger side of the dash where it joins the lever mechanism. Any info/ ETCA diagrams etc appreciated. VBR Ian.
Old 05-05-16, 12:15 AM   #2
Hanuman
Hanuman's Avatar
i've a couple, I can send to you, if i find them. friable bushes, also across the entire VAG range. i'll post some info shortly
Old 05-05-16, 12:18 AM   #3
Hanuman
Hanuman's Avatar
Audi 100/Avant
Audi 80/90/Avant
Audi 80/90/Avant quattro
Audi Coupe
Audi Coupe quattro
Audi quattro/Sport
Audi 4000
Audi 4000 quattro
Audi 5000
Audi Fox
Audi Coupe
Audi quattro
Volkswagen Caddy
Volkswagen Golf
Volkswagen Golf Cabriolet
Volkswagen Jetta/syncro
Volkswagen Passat/4Motion/Santana
Volkswagen Passat syncro
Volkswagen Scirocco
Volkswagen Santana/Variant
Volkswagen Santana 2000/3000
Volkswagen Rabbit Conv./Golf Cabrio.
Volkswagen Dasher
Volkswagen Fox 302,307,309
Volkswagen Jetta
Volkswagen PickUp
Volkswagen Quantum
Volkswagen Quantum syncro
Volkswagen Citi Golf
Its actually this bit-
431721559
. Item 6 and item 7 being the same part. So fit two new ones.
Old 05-05-16, 10:10 AM   #4
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Same thing happened a year or so ago, try this.http://www.ebay.co.uk/itm/VW-T4-TRAN...item336c97dbb9
http://www.oesems.co.uk/
Old 05-05-16, 08:35 PM   #5
Thanks folk that's superb.
If you've got one Mark, yes please... it looks like item 7 for a RHD car.
Old 05-05-16, 08:49 PM   #6
Hanuman
Hanuman's Avatar
I'm not back in the uk/south for a few weeks. I'll see if I can get someone to dig them out.
You do need two. The cable hooks into one, mounted in the balance lump, IIRC, and the balance lump hooks into the second which is mounted in the transfer arm.
They're reasonably cheap, though. Or they were.
Looking at the thread on the other channel, JimH used the ones that Darreno'd linked to above.
Old 05-05-16, 10:13 PM   #7
jimh
Yeah, use that Ebay one. It's much better than the original. The Ebay one is made out of some kind of rubber,the original one appears to be made out of some kind of soft foam which eventually crumbles to dust.
The ebay one was easy to fit with some mk1 spittle lube and pipe wrench type pliers, but only if you assemble in the correct order. I think the bush needs fitting into the lever before the cable is fitted to the bush which ISTR being counter intuitive at the time.
The cable feels nice and secure in the Ebay bush and I haven't noticed any downside.
Old 07-05-16, 01:33 PM   #8
Thanks folk,
I have had a chance for a closer inspection today and 'found' this, which I assume is item 5 resting behind the carpet...
As a temporary fix to get the car home I had just attached the cable straight to the lever and adjusted the cable accordingly, not realising there was a chunk of metal called 'item 5' missing.
The question is, what does item 5 actually do?
This is what the RallyRep looks like which is the CQ set-up...
PS - Just ordered a couple off ebay...
Old 07-05-16, 04:57 PM   #9
Lofty
Lofty's Avatar
Get the Volkswagon equivalent as it does not disintegrate like Audi's.
For some reason VW use urethane bush rather than the rubber Audi one.
Old 07-05-16, 05:56 PM   #10
GBT4
The metal piece is just a weight probably to aid the return of the pedal to its home position. You need two of those bushes did mine today!!!
Sent from my SM-N910F using Tapatalk
GBT4 is offline   Reply With Quote
