Members: 19,779 | Total Threads: 40,092 | Total Posts: 471,088 Currently Active Users: 2032 (1 members and 2031 guests) Welcome to our newest member, Robinceabe |
i want more power out of my s4 , apart from chipping or remapping any othern good options ? cheers
How much power do you want?
1992 UrS4 |
That's a good question, the sky's the limit with a 20vT...
A remap and a bigger intercooler will see you knocking on the door of 300 (290ish). But, and this is a big But... It's got to be spot on healthy first... Anything that resembles a weakness... sensors not working properly, boost leaks (a classic nightmare fault), fuel starvation at full boost etc will all become much bigger issues when upping the boost... A kkk24k is good for circa 300bhp, anything after that is a turbo change... Conventional wisdom says 350 for standard rods, (achieved with RS2 inlet/exhaust etc) but I've seen 400 running standard bottom ends... Then, after the 'scat' rods and modified pistons rebuild on the bottom end and custom remap it's just a case of modified inlet, exhaust, turbo, intercooler and fuel/mixture control... All the way to the 1000bhp blocks...
Oh, I forgot, also a huge bank account, 20vT's are cheap hp in name only...
Yes, 285bhp can come cheap, but the jump to 315bhp/350bhp is expensive... The next 'expensive' jump is over the 380/400bhp (bottom end) hurdle.
Keeping within stock rev limits will go a long way towards keeping it all reliable.
Javed from 034 motorsport ran a 10valver -unopened engine btw, for two years in race trim at outputs of 500bhp ish before he lost a valve head which destroyed the motor. 20valvers got more potential for sure so i dont see 400bhp being beyond std components if detonation is avoided and fuelling and coolngs kept under control. I certainly hope to see 400 bhp and then some on the 20 vt i have... |
| More power for NF engine | pimpdriver | Engine | 3 | 14-08-09 05:09 PM |
| 6a / ACE Engine Wanted | T0MME | Parts Wanted | 1 | 09-06-09 08:49 PM |
| kg power | 100turbo c | Engine | 2 | 23-11-08 09:52 PM |
| Wanted,both exh manifolds for a 2.6 V6 ABC engine | SteveCat | Parts Wanted | 1 | 10-09-08 08:24 PM |
