Members: 43,064 | Total Threads: 40,086 | Total Posts: 471,053 Currently Active Users: 12458 (3 members and 12455 guests) Welcome to our newest member, JeffreyVak |
#11 |
yup, this photo here looks pretty much like mine - a lot of big blanks in there . . is that it?? i was expecting to see loads of fuses in there . .
https://www.google.co.uk/search?q=ur...0%3B1000%3B775
1997 Audi S6 Ruby Red Last edited by geneandbolly; 19-06-14 at 11:34 AM. |
#12 |
It's worth noting that the engine speed sensor fault code will always be there unless it's cleared with the engine running, if the speed sensor is in fact faulty I very much doubt you'd be able to start the car. The speed sensor code will reappear after each restart as it's triggered as soon as you turn on the ignition with a static engine.
The hesitation sound like coil packs or the associated low tension wiring. ISV and N75 are indeed on the same fuse. |
#13 |
Check fuses for sure Craig and get rid of the bleed off valve that is inline with the lower wastegate hose and the N75 then give it a shot again.
#14 |
Ahh, there was no mention of a bleed valve before now, their dreadful things, get rid of it ASAP! Seriously though that really isn't the way to go about getting more from these engines, it could also be causing the N75 fault.
#15 | |
Black Coupe Collector
The main fuse panel is on the end of the drivers side of the dashboard behind a half moon shaped panel http://12v.org/urs/RHDDriversEndDash...owingFuses.jpg
95 UrS6 87 Coupe Quattro |
#16 |
Would the bleed valve not cause a code as the ecu is not seeing the boost it specifies?
Get the bleed valve off, and once the car is running properly get a proper 285bhp chipset, not expensive and will transform the car.
#17 |
Yep, that's what I was thinking, the MAP sensor is going to be seeing more boost than is specified for a given throttle position, hence the N75 fault code.
#18 |
thanks for your suggestions, chaps. martin spotted that bleed valve thing and i'll get that removed asap and take it from there. will be interesting to see if there's any improvement once that's sorted. as for the fuse box, both ends of the dash stated "danger - airbag" so the fuse box definitely isn't housed there. all i can see is that half empty relay box under the driver's wiper arm area.
1997 Audi S6 Ruby Red |
#19 | |
My cover has that message on it too, the message has nothing to do with the cover on the drivers side, its just a handy place for Audi to place their H&S warnings. At the bottom of the cover there is a cutout, that is where you can get something in to open the cover for the fuse panel.
#20 |
Thobbing Member
S6 fuses are behind the cover on the end of the dash - check the ISV & N75 fuse, AFAIK the N80 is on that fuse too, so I'd expect a code from that too if the fuse was blown.
I agree with the above - get rid of that bleed valve AKA detonation device ASAP and then reset the ECU and recheck codes. If the ECU detects too much boost AFAIK it will pull the timing anyway so bleed valve is useless on these motors, leave them for the rice kids and their tonka toy turbo set-ups. |
