Classic Audi » Technical » Mech/Tech » Transmission » Torque Convertor removal
Old 27-10-13, 10:47 AM   #1
andydunn2
Ragtop Collector
Default Torque Convertor removal
Ok any tips on removing the torque Convertor on a AAH (2.8 v6) just giving it a quick look and I couldn't see any obvious bolts holding the torque Convertor to the flywheel.
"Earl" 1998 2.8 V6 Cabriolet
Old 27-10-13, 11:00 AM   #2
spink
3 bolts hold it onto the 'flywheel' from the engine side.access to the bolts should be in the starter motor mounting hole
Old 27-10-13, 11:06 AM   #3
andydunn2
Ragtop Collector
Top man
Old 27-10-13, 11:16 AM   #4
spink
Thats the easy bit, getting the boss out in the end of the crank can be a twat.
Apparently a 24 or 27mm(not sure which) drill bit can be used to just drill it out
Im presuming you are converting that engine to a manual car?
Old 27-10-13, 11:36 AM   #5
andydunn2
Ragtop Collector
Thanks, yep its a replacement for my manual cabby.
Looks like this will be a fun job..
