Members: 43,052 | Total Threads: 40,086 | Total Posts: 471,045 Currently Active Users: 4881 (2 members and 4879 guests) Welcome to our newest member, LeonelHip |
Not the usual problem like it's stuck in, quite the reverse actually, i am trying to tighten the nut up but the thread keeps on turning, i have tried pressing it in with slip joint pliers and mole grips gripping the handle of the pliers, so that's a lot of prssure but still the damn thread turns.
help any ideas??? Ta james |
#2 | |
Pry bay or suitable other bar between the top of the offending balljoint and a big block of wood and a suitable point on the suspension or floor to pry against, effectively multiplying your holding pressure. Wire brush the theads first on the balljoint if its an old one and clear any debris out or itll make it a hell of a job to get tightened. |
Replace offending part (I give in easily these days!!)
“Been raced and rallied”
Is it the right part / size ??.
Ragtop Collector
Check the condition of the thread and make sure its not fooked, if its damaged then the nut wont screw on easlily creating more torque and hence the problem.
I had this issue on the GT with track rods from Eurocarparts, cleaned them up with a file and bobs your aunty..! |
![]() I normally use an air ratchet where I can, find it's ledd prone to spinning the ball joint.
I use a two-arm puller upside down, so it's pressing the joint into the arm. You could try taking it off again if you can and then you can give the mating surfaces a really good clean, as sometimes a little bit of grease causes this problem.
This can also be caused by not cleaning the threads on an old joint properly, or reusing an old rusty nut (nuts should be replaced every time - they're really cheap!). Paul |
Puller has now worked so thanks guys, just finished in time for it to start pissing down
J |
