Classic Audi » Technical » Mech/Tech » Transmission » Gearbox for TDi into B2 80
Old 19-07-10, 10:13 PM   #1
markb
Default Gearbox for TDi into B2 80
Hey,
I'm about to start a TDi engine swap into my 1986 80 GL but I don't think the present ratios are ideal for the TDi.
Currently when doing and indicated 70 the engine is at ~2900RPM.
Is there 'box from another car (maybe a later 80 or passat?) that will fit and will have better ratios?
I suppose one thing that may have an influence is that my 80 has a cable clutch at the moment, but I am assuming most of the later 'boxes will have hydraulic clutches, so how hard is it to convert my 80 to hydraulic clutch?
Any help much appreciated.
Cheers,
Mark.
markb is offline   Reply With Quote
Old 20-07-10, 05:28 AM   #2
B2 90s have hydraulic clutch.
Sounds an interesting conversion I have thought of before.
Old 20-07-10, 06:33 AM   #3
JMLAudi
JMLAudi's Avatar
Default tdi box
hi
i got a cheap good condition gearbox if interested,located in Bradford
PM me
cheers
john
Old 20-07-10, 08:52 AM   #4
markb
I love diesels me, I can't seem to have a car without wanting to diesel it...
This one is going to get a mechanical pump from a discovery, making it an m-tdi. Just to confuse things even more, I'm putting a VNT turbo from a crafter van on it which will be driven by a VNT controller I'm designing.
Hi John, well I could be interested, but I don't even know what gearbox I'm looking for yet... What is this one from? are the ratios diesel friendly? Will it fit my 80 with no mods, some mods, etc.
Mark.
Old 20-07-10, 09:45 AM   #5
JMLAudi
JMLAudi's Avatar
Default gearbox
Hi Mark
Yes gearbox is from a M REG 1.9 tdi Audi 80 Avant....should bolt up easy
but i dont have spare set of driveshafts for it though
where you based?
Cheers
john
Old 20-07-10, 11:58 AM   #6
90Quattro
90Quattro's Avatar
get a 6speed from the later passats/audis be well worth the extra effort in long run
Old 20-07-10, 12:09 PM   #7
markb
My B2 80 quattro is hyd clutch as well, so i'm assuming it shouldn't be a big issue, but havn't looked yet.
John, Do you know if the Driveshafts are the same? i.e. length and CV size? Also, is it hydarulic clutch? Oh, and cable or electronic speedo?
90Q, I do like the idea of the 6speed, have you any idea how much work is involved in fitting one?
Old 20-07-10, 04:38 PM   #8
Only thing why this is still interesting is low amount of old audis left on british roads + price for such conversation in UK would be astronomical. But in latvia it's now common - 2.5 10v TDI are being stuffed into B2's, B3's [coupes, A90, both fwd and quattro], B4 [but less common, since B4 got 1.9 TDI], C3 A100, A200 both fwd and quattro, and also in C4 that originally got petrol engine - I, for example, know one UrS6, which now can be called "Audi A6 2.5 TDI quattro avant", since it's not S6 anymore And there is two reasons for this - ppls who doesn't calculate total costs or ppls, who buys stolen [usually employee sells fuel saved on he's work vehicle] diesel, so there is economy [current diesel prices in latvia, I presume, is somewhere around 75-80 santims per litre, stolen diesel usually goes around 45 santims per litre, 1 pound = 80 santims for comparision]. I actually hate to see this. Some time ago I dreamed about such engine for my A90q, but not anymore - since I would use petrol stations as with A80, economy from consumption differences between 2.5 TDI and NG would be enough low that I could say "I'm not that rich to use old diesel engine". And after all, audi isn't any crap car, so it must have proper engine, not tractor engine.
Ah, one more difference between UK and latvia - in latvia only rare AAT have still 115 bhp and rare AEL have 140 bph, usually there is at least performance chip installed, but some goes further. I know one person, one year younger than me, who has A200q with 2.5 TDI, probably now somewhere around 200 bhp and at least 400 nm, but I think that's old news. Some time ago he planned to install VNT turbo and for this ECU from newer model 1.9 TDI, so probably he now has more power. And he's not the only one like that.
Old 20-07-10, 05:47 PM   #9
dandan
big gimping
dandan's Avatar
hello i own a TD B2 80 good luck with your engine swap what hp you think it'll be running?
dandan is offline   Reply With Quote
Old 20-07-10, 09:08 PM   #10
markb
Hi dandan, I've seen your posts before and believe me, i'm jealous! Have you tuned your engine up at all? I've put an AAZ (1.9TD) into a caddy and a mk2 golf and will be doing an old skoda felica pickup soon.
I don't expect to be running anything too impressive, this is my daily driver, but maybe around 120bhp?
