Classic Audi » Technical » Mech/Tech » Engine » any ideas ??? won,t fire up
Old 08-04-10, 10:38 PM   #21
missfire
missfire's Avatar
Originally Posted by jack1 View Post
hi all, after replaceing the fuel distributor block on my 100 type 43 fuel is now getting to the injectors but seems to be to much as its flooding the plugs the mechanic tried adjusting but to no avail ,so its now gone from( no fuel )and now (to much),, any ideas yet to be driven on irish soil
re-reading it..and if its not the fuel distributor..
fuel pressure regulator poopahoopeid..??
sounds like the systen may be receiving full pressure from the pump..not a regulated control pressure..??
expensive wee bits of metal though
Old 15-04-10, 03:39 PM   #22
jack1
if it was to be this would the car not even try to start as it only turns over and over and makes no attempt to fire at all ,,,would this also known as the fuel accumalator that sits beside the pump?
Old 15-04-10, 05:33 PM   #23
Default Read this,might help?
http://www.classic-audi.co.uk/forum/...ead.php?t=6933
Old 15-04-10, 08:27 PM   #24
missfire
missfire's Avatar
no. on mine the pressure regulator is beside the metering head (kind of in the wing)
on yours it will probably be integral to the metering head.( a little shuttle valve i think)
biggyin is the man with the diagrams though..!
biggyin do you have a cutaway pic or location pic for the pressure valve in the head..?
Old 15-04-10, 08:48 PM   #25
jack1
today i fitted a new filter and fuel pump and when checked there was massive pressure at the filter ,so i then pulled 2 injectors and fuel is getting through in a fine spray so surely the car should try to start but no it still just turns over and over ,so tommorrow all plugs get changed and injectors wiped clean as there was alot of black gritty residue on the 2 i pulled
Old 15-04-10, 08:57 PM   #26
when I had that sort of problem years ago with a 2.8 Capri the more it turned over it would not fire for ages .the very nice man came around took out all the sparkplugs and heated them up with a lighter to remove the residue fuel and turned over the engine to remove the excess fuel in the cylinders put back the plugs and the bloody thing fired
All it was i flooded it
just an idea ya never know
Old 15-04-10, 09:04 PM   #27
jack1
micky im at the stage i will try anything now, after 4 months with the so called audi mechanic i collected it with every part i gave him stiil on the floor so im now going to have a go myself,what have i got to loose((only my mind))
Old 15-04-10, 09:15 PM   #28
i am at a loss m8 if you were in the uk i would have helped you .its hard to do anything on the interweb just hope you can sort it . good luck and let's hope you do get to drive it on Irish soil
Old 15-04-10, 09:32 PM   #29
Went to take pics,camera batteries dead.I,ll charge one and then post pic.
Do you mean the pressure regulator?
Old 15-04-10, 09:37 PM   #30
missfire
missfire's Avatar
this thing
on page 10 of this...thing...pdf..??
http://www.porsche928forums.com/down...CISRebuild.pdf
it could be responsible for the 'too much fuel 'thing.?
need some ideas ? Micky General Chat 25 25-01-10 11:37 AM
Problem, anyone any ideas? Sie! Suspension & Brakes 15 08-07-09 11:26 PM
Anyone any ideas ! Audi Dec Suspension & Brakes 0 24-06-09 11:53 PM
ideas please Micky General Chat 14 08-05-09 04:39 PM
