Classic Audi » Classifieds section » Parts Wanted » Audi 200 speedometer wanted 1989
Old 10-06-09, 11:45 AM   #1
kim
Default Audi 200 speedometer wanted 1989
Hi,
Can anybody tell me if there is a way to obtain a speedometer for an Audi 200 1989 manual?
Mine needs to be replaced, byt it is NLA.
Thanks.
Regards,
Kim.
kim is offline   Reply With Quote
Old 10-06-09, 11:48 AM   #2
is it just the speedometer or all of the clocks???
What is the problem with it, we may be able to help, as the 100/200 speedo has a habit of not working due to dirty contacts.
Cheers
Steve
Old 10-06-09, 12:13 PM   #3
kim
Hi Steve,
It is just the speedometer. But it also affects the Cruise Control (not that I use it much).
But the fact is that once I go over 80 mph, the mileage meter stops.
So it is a bit annoying to keep track of the miles done.
Thanks for you help in this.
Regards,
Kim.
Old 11-06-09, 05:32 PM   #4
crisarc
is it the big dash model? as i have a dash set from the earlier model if required....
Old 11-06-09, 06:36 PM   #5
Well, that's interesting. Speedometer needle in that moment goes to zero [ok, there isn't zero ] as well?
One guy, who often changes something in he's C3 2.5 TDI, once me said that speedo clocks are interchangeable from all speedos, that have mechanical odometer - so basically B3, C3 with new interior, B4 and C4 A100.
Old 12-06-09, 07:53 AM   #6
kim
Hi Steve,
Sorry, but I don't understand what you mean by "big dash model".
I am not too technical.
Thanks.
Regards,
Kim.
Old 12-06-09, 07:59 AM   #7
I think with "big dash" he meant new style dashboard, which u must have, because it was in A200 from 1988. and A100 in 1990
So he have old one which will not fit in your A200
Old 23-06-09, 06:18 PM   #8
5potnoodle
OCD member
5potnoodle's Avatar
It will affect quite a few things if your speed signal is not being forwarded by your speedometer. See my speed signal fault finding procedure pdf at www.audi200.org.uk
I'd suspect dirty contacts on the rear of the instrument cluster. It's an easy-ish removal from the "eyebrow dash" type44s like yours. It easiest if you remove the steering wheel first but can be done without. The usual culprit is where the speedo plugs into the printed circuit board. The long pins get tarnished over the years and decrease in conducting efficiency until you get to the dash-slapping stage. A sharp tap on the top of the dash above the speedo can sometimes restore the speedo for a moment or two. I suggest if you can do this and it starts working again, you have the usual fault. I will do a procedure and post it here or on my website (or both) later.
Current:
99 Subaru Forester S-Turbo Auto - interesting... but it's not a quattro
91 Reliant Scimitar SST 1400 - no.39 of 42... something for the weekend
Previous:
Two consecutive 1989 Audi 200 Quattro Turbo Avant, 1B
1990 Audi 100 SE Avant, NF
1986 Audi 100 CD Avant, KU
1987 VW Passat GL5E Estate, JS
"Honorary" triple member of the 200,000+ Club
Audi 200 in the UK (legacy website)
Classic Audi member no: 258
5potnoodle is offline   Reply With Quote
Old 08-07-09, 08:39 AM   #9
kim
Hi,
Thanks for the explanation. I will wiat though for you procedure, so I can follow this step by step.
Regards,
Kim.
Old 08-07-09, 07:23 PM   #10
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
Kim have you seen this it might do the job..
http://cgi.ebay.co.uk/Audi-100-saloo...3A1%7C294%3A50
1989 B3 Audi 80 Nothelle Coxy Cars For Sale 11 23-11-09 12:22 PM
Audi 2.0e 1989 for sale jabba Cars For Sale 6 28-07-09 08:48 AM
1989 1.8s Audi 80 poopcoupe Cars For Sale 1 03-12-08 01:26 PM
Leather interior wanted for 1989 coupe smudger41 Parts Wanted 0 03-03-08 04:23 AM
Audi 200 Turbo 1989 - 38K !!! randall977 Cars For Sale 5 18-10-07 03:59 PM
