Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Bonnet release cable SNAPPED !!!
Old 21-01-10, 08:43 PM   #11
davow
davow's Avatar
cable on my old b3 coupe went a bit slack once and couldnt open it, bent a length of 1/4" bar about 2" from the end at 90degrees, cut a slot in it, and poked it through the grill, locate the cable through one of the holes in the metal work near the catch 'and gave it a good tug' (no reference to missfires latest keira knightely post!) and the bonnet will open! I have the said tool (not missfire) sat in the top of my tool box unused for the last 8 years gathering dust so if your really struggling its yours! other advice is to get an a2, you dont have to open the bonnet on them till they have there own section on classic audi!
davow is offline   Reply With Quote
Old 21-01-10, 08:55 PM   #12
missfire
missfire's Avatar
ha....ha.....that thread was an advert for pimpdrivers 'bump-stop thread'...and originally contained nothing elicit whatsoever....
you can blame all the 'dirty old men' on here for continuing it...and adding all the tug material.........
i am a saint....
Old 21-01-10, 09:08 PM   #13
davow
davow's Avatar
i am a saint....
missfire, your crap! you could have picked up on the words :- slack, length, end, slot, poked and box on that last reply, what you playing at????
Old 21-01-10, 09:31 PM   #14
SPECKY
SPECKY's Avatar
Thanks for some of the helpful posts so far !!!
Old 23-01-10, 09:00 PM   #15
SPECKY
SPECKY's Avatar
GOT IT !!!!!!
Managed to see the broken cable from lever end today. It was in the outer sheath so had to cut 1/4 inch of outer off to grip and got it open.
Thing is..........
I have read that a Tandem bike cable will work, but its 1.5mm dia and the original i have removed today is 1mm dia................ CONFUSED
Wondering now if i should go for original replacement from Stealers ????
Old 26-01-10, 06:31 AM   #16
SPECKY
SPECKY's Avatar
Ok...... JOB DONE.
Its been modified and Speckyfied !!!! The joys of workin at a decent engineering place
Have also fitted 2 Stainless 0.6 Dia wires to each release and fed them neatly into the fron of radiator and grill area so if i have same problem again i can use these to release.
New cable from stealers was gonna be £24...... NOT AN OPTION
SPECKS
Old 26-01-10, 08:09 AM   #17
missfire
missfire's Avatar
well done with the emergency cables......cunning..
these work.......
Old 11-06-12, 05:41 PM   #18
doninphi
doninphi's Avatar
Where did you get a new one from? Non for a b2 on ebay or GSF... ???
Mine went when trying to refit it! (booo)
I make vinyl STICKERS! Pm me for any design you want...
doninphi is offline   Reply With Quote
Old 30-06-12, 04:09 PM   #19
doninphi
doninphi's Avatar
Gsf don't stock them....
Wonder if a mk2 golf one fits???
bonnet release (or not ) cable john johnson Bodywork, glass & exterior fitments 12 12-09-09 11:41 AM
Wanted bonnet cable and attachments for 1987 style coupe mjl16v Parts Wanted 5 03-01-09 02:42 PM
My bonnet cable has broken! mjl16v General Chat 0 01-01-09 12:17 PM
Audi 100 no brake lights and won't release from park when engine on - HELP!!! 20vquattro Suspension & Brakes 5 18-08-08 02:13 PM
