Classic Audi » Technical » Mech/Tech » Engine » kv non starter
Old 23-09-09, 07:25 PM   #1
stoop44rio
Default kv non starter
can a petrol engine become air locked? just changed the fuel filter and now have a non starter!! well starts for maybe two seconds then stops any ideas??
stoop44rio is offline   Reply With Quote
Old 23-09-09, 07:32 PM   #2
4v6
Lol you got the filter on the right way round then?
cant become airlocked as the pump will force fuel around the system.
Likely youve disturbed the wiring plugs to the pump perhaps?
Old 23-09-09, 07:46 PM   #3
stoop44rio
dont think i did but will double check tomorrow. anything else i could look over?
Old 23-09-09, 07:47 PM   #4
stoop44rio
dont think i did but will double check tomorrow. anything else i could look over? it has started once and run for several minutes then cut out and hasnt restarted
Old 23-09-09, 08:22 PM   #5
One thing to try,is the fuel pump relay???????
On one of mine,it would start,run for 20 minutes and then cut out.I thought it was dirt in the tank(or clogged,fuel filter),because after leaving it for about 10 minutes,it would start(1st time)again.I thought, it could be the dirt settling back down.
I changed both fuel filters,to find(in the end) it was a faulty fuel pump relay.
Old 24-09-09, 08:37 PM   #6
stoop44rio
changed the relay last week also. wheres the second fuel filter? done the one at the pump/ accumulator
Old 24-10-09, 07:08 PM   #7
Did you get her going in the end?
If so what was wrong?
Old 24-09-09, 08:50 PM   #8
it's only the early cars (pre 86) that had the pre-filter.
A non starter on the KV can only be one of two things. spark and fuel. Unless the timing has gone miles out but unlikely in this case
Are you getting spark ?
Are you getting fuel through ?
1991 90 quattro
Old 27-10-09, 12:19 PM   #9
BigT80
A little late to add to this thread, but I also have a KV with similar symptoms. A few months back I had troubles as posted on here, which turned out to be seized pump. Car since been in for some bodywork & now runs like a pile of s**t. Won't run after initial start until coaxed with lots of throttle prodding & gradually building up revs; so thought warm up reg, but when (eventually) warmed would rev, but died as soon as you go to pull away. Tried pump - yet another: & + terminal snapped off the new pump. taped up connector just to try it & no different. So will try another pump I know is good & then poss Warm up Reg. I wonder if blocked filter would cause it, or accumulator not doing it's job, but I thought that was just to keep pressure in system? I'll have another go tomorrow, but any thoughts meantime? Sorry to highjack thread, but seems you're sorted stoop44rio Cheers. G.
BigT80 is offline   Reply With Quote
Old 27-10-09, 05:40 PM   #10
Undo the banjo bolt at the strut turret and check for debris - both in the line and also in the banjo itself.
You can use the Z bridge from position 8 in the fuse box in place of the fuel pump relay to run the pump and push fuel through.
If there is any debris, dump a bottle of injector cleaner in the tank.
I've just had this on mine after replacing fuel lines. The banjo bolt was partially blocked. After clearing th debris, the car wouldn't run properly but the injector cleaner has cured that
1991 90 quattro
Audi 200 turbo starter motor...grrr 86audicoupe Parts Wanted 11 22-10-09 08:33 PM
80 quattro - Non-starter BigT80 Engine 17 06-08-09 05:46 AM
best place to get a new alt, starter and water pump?? xXbullXx General Chat 3 23-02-09 12:45 PM
Starter Motor - KV Booty Parts Wanted 7 15-02-09 05:18 PM
