Classic Audi » Technical » Mech/Tech » Wheels & Tyres » wheel bolts length !? :(
Old 12-05-09, 07:04 PM   #1
Gaz
Gaz's Avatar
Exclamation wheel bolts length !? :(
*Sigh*
Was going to fit the borbet A's today and have noticed another problem.
Looks like my wheel bolts aren't going to be long enough?
After placing a bolt in the wheel I first thought i was going to still have enough length, but then noticed that some of that thread is going to be lost by the thickness of the brake disc.
So, my two questions are, Exactly how much thread do i need protruding from the wheel for it to be 'safe' ?
And from where can i get longer wheel bolts?
cheers.
Gaz.
Old 12-05-09, 07:08 PM   #2
I may have some spare bolts you can have. I got loads with my new wheels. I'll ship them out with the cam if you want to try them, there not much use to me.
Old 12-05-09, 07:10 PM   #3
just an idea just push a standard bolt threw a standard wheel and see how mutch sticks out
Old 12-05-09, 07:15 PM   #4
Probably a better/easier method Micky... Saves having to clean up the threads afterwards...
ISTR standard are 35mm, 40mm are available too.... (don't quote me on that though).
Old 12-05-09, 07:21 PM   #5
vag80
vag80's Avatar
If your car has drums on the rear be carefull with the lenth of bolt you use i have had it before were i've fitted longer bolts only to find they were alittle to long and were catching on the brake shoes.
if you have discs all round then it's no prob
200k club member
87-b3 80
83-4000 2 door
Old 12-05-09, 07:22 PM   #6
Good point....
Had that with my old GT... Had the longer bolts machined down a bit...
Old 12-05-09, 07:39 PM   #7
You should have at least 6 - 7 full turns on a bolt. I had these issues with my Ronal when i fitted the spacers. Demon Tweeks helped out and sold me 16 of their longest. Give them a call ( infact pop in as it's only down the road from you ).
Old 12-05-09, 07:42 PM   #8
Gaz
Gaz's Avatar
That sounds great!
With any luck they might do the job!
thanks.
Old 12-05-09, 07:10 PM   #9
Originally Posted by Gaz View Post
*Sigh*
cheers.
Gaz.
Clean up a standard bolt, put some graphite gease in the hub thread, and re-fit the standard alloy... This'll give you a good idea how many threads 'bite' on the hub.
And
Yes you can buy longer bolts, but make sure the bolt head angle matches the alloy...
You don't want a 'V' shaped head in a 'U' shaped hole... (said the actress to the Bishop)
20 off wheel bolts for steel wheels pimpdriver Parts Wanted 2 02-12-09 08:18 AM
speedline rivits/bolts Tone Wheels & Tyres 4 27-08-09 07:48 AM
Name that wheel! Puglife General Chat 22 11-08-09 08:12 PM
oil cooler shield bolts stuartmmcfc Bodywork, glass & exterior fitments 8 05-08-09 07:44 PM
Speedlines & dummy bolts on ebay rsk289 Parts For Sale 2 06-03-09 10:40 AM
