Members: 19,823 | Total Threads: 40,093 | Total Posts: 471,115 Currently Active Users: 2313 (0 members and 2313 guests) Welcome to our newest member, BuddyInons |
Have a Garrett turbo here, been asked if its a K24 7200 alternative turbo for a WR
ANSWERS on a p/c please came in the box of engine bits from the donor quattro. Thought they had KKK's
is it one of the 034 garrat replacements take a look at the part number and go check on there site www.034motorsport.com try that rich
ok thanks John....
ok its got the following stamped onto it BCC1 M24 A/R42 4N9115 34 on the hot side it has 10042 on it
A/r42 seems to say "a/r ratio" to me.
(Following is taken from an article on the web) The turbine housing A/R (area/radius) ratio is the area (A) of any turbine inlet scroll cross-section divided by the distance from the center of that cross-section to the center of the turbine shaft (R). For any given turbine housing, A and R vary in the same proportions, so all As divided by their corresponding Rs yield the same dividend--which is the A/R ratio. But brute size is not all that matters. The turbine's A/R (area/radius) ratio basically determines where the turbo starts to accelerate. A turbine housing looks kinda like a big snail shell. Unwrap the shell and it resembles a cone. Cutting off the tip of the cone leaves a hole--the cross-sectional area of this hole is the A in A/R. The hole size is important since it determines the velocity at which the exhaust gases exit the turbine scroll and enter the turbine blades. For a given flow rate, the smaller the hole, the higher the velocity--but the greater the restriction to exhaust-gas flow The R in A/R is the distance from the center of the cone's cross-section to the center of the turbine shaft. A smaller R imparts a higher rotating speed to the turbine; a larger R gives the turbine shaft greater torque to drive the compressor wheel (because the lever arm R is longer). ![]() |
of course it is... silly me for not knowing that
![]() ![]() thanks for the explanation and wee diagram. so is this a "tuned" turbo that I have or standard? ![]()
yes you are right they do have kkks as standard, wr ,s have k26,s and mb ,s have k24,s look on the bearing housing for a garret part number , there should be a little tag attatched to the bearing housing , if not it may have fallen off nothing on the comp cover will really tell you
| Rims question... | oldschool81 | Wheels & Tyres | 5 | 15-01-10 11:15 AM |
| question ? | Micky | General Chat | 17 | 06-12-09 09:39 PM |
| Question ? | Micky | General Chat | 9 | 24-12-08 10:01 PM |
