Classic Audi » Technical » Mech/Tech » Engine » Which antifreeze for a 200 Quattro Turbo?
Old 20-12-20, 03:22 PM   #1
Modus
Default Which antifreeze for a 200 Quattro Turbo?
Can it take the red OAT antifreeze? If not, which types of coolant can it take?
Car is a 1987 2.1 turbo model
Modus is offline   Reply With Quote
Old 20-12-20, 05:18 PM   #2
Definitely not red.
You want either G11 (blue) original type or G13 (purple) latest.
1991 90 quattro
Old 21-12-20, 12:09 AM   #3
Gaz
Gaz's Avatar
What's wrong with using the OAT providing whatever was in their was fully flushed out so no cross contamination?
Old 21-12-20, 08:02 AM   #4
The OAT stuff doesn't like yellow metals as far as I'm aware
Old 21-12-20, 05:17 PM   #5
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
I would recommend G11 as this is what was originally used. I have used this in my Coupe GT.
Old 22-12-20, 08:44 PM   #6
Gaz
Gaz's Avatar
Ah I see.. which parts of the engine does it effect?
I'm sure I read that the older OAT stuff had issues of some kind with something in engines but the very latest OAT stuff isn't affected with the same problems?
I don't know if this yellow metal issue was the old issue ? Or if that was something different altogether?
Old 22-12-20, 10:14 PM   #7
Just to pick up on this, I never said for or against OAT.
I specifically said, don't use red
Red is G12 and was only used for a short time when all alloy engines were first fitted to Audis in the mid to late 90s. It wasn't backward compatible with G11.
The latest G13 is backward compatible and can be mixed although a flush is usually recommended.
This gives a decent summary
https://www.ato24.de/en/blog/which-coolant-antifreeze/
1991 90 quattro
Old 23-12-20, 08:09 AM   #8
Anything with brass or copper but I think you're right, it was an issue when the OAT stuff first came on the market?
I would think the owner's handbook will say use an ethylene glycol based antifreeze and to change it every 2 years, at the time it'd be blue in colour.
