Classic Audi » Classifieds section » Parts For Sale » New shocks, calliper and a fuel pump relay!
Old 05-05-12, 08:47 AM   #1
Rapidresto
Default New shocks, calliper and a fuel pump relay!
I first posted these back in the early days of classic Audi in 2007 when I was rolling around in a 2.3 coupe and a 80 avant!
They have sat in the various sheds / garages across the country ever since and whilst the boxes have become a little more tatty the parts are still spot on.
Fuel Pump relay - Brand new in box, slotted it in to check mine wasnt at fault but it wasnt the relay that was causing the trouble (turned out to be a dodgy breather pipe) genuine vag, brought for 91 2.3 ng engine, but i'm sure it'll fit others. Cost me a small fortune, but yours for just £10.
new front shock inserts (brought for 95 80 avant tdi but may fit others) sachs / boge £20 pair.
New front caliper (girling) (brought for the coupe but will also fit others) offside £20
will post (via courier at very reasonable cost) / can be collected from Telford.
Rapidresto is offline   Reply With Quote
Old 06-05-12, 10:41 AM   #2
CharlesK
CharlesK's Avatar
Might be interested in the shocks for my 100 Quattro. How do you go about changing the shockies on these?
CharlesK is offline   Reply With Quote
Old 06-05-12, 08:41 PM   #3
Rapidresto
The shocks are inserts, you have to take the strut out and the spring off (using spring compressors) swap the inserts and rebuild.
Old 06-05-12, 09:09 PM   #4
spink
front shocks on type 44s and c4s can be changed in 5 minutes or under using the special tool
Old 06-05-12, 09:31 PM   #5
Rapidresto
5 mins! That's some special tool.
Old 06-05-12, 10:16 PM   #6
spink
my apologies,i meant 4 minutes
Old 07-05-12, 12:32 AM   #7
urS6
I've got the tool - used it about four times now. I've always had to replace more stuff than just the insert, so I've never got close to the fabled 5 mins. It is MUCH nicer to use than a humongous Stilson and saves you cringing with embarrassment whenever friends spot the tell-tale teeth marks on the cap.
Lots of people have made their own 2069. See http://forums.quattroworld.com/a6100/threads/2.phtml.
urS6 is offline   Reply With Quote
