Classic Audi » Classifieds section » Parts Wanted » 1990 Audi 2309cc 20v Coupe Quattro
Old 03-01-11, 11:50 AM   #1
ksaudi
Default 1990 Audi 2309cc 20v Coupe Quattro
Oil Pressure and Oil Temperature Gauges needed - also Senders as back up.
Also Diff Lock not working but unsure of problem - interested in any likely parts.
Thanks
Keith
ksaudi is offline   Reply With Quote
Old 03-01-11, 09:35 PM   #2
Richie
Richie's Avatar
got a set of gauges in the 90 sport I am breaking if your interested?
Old 04-01-11, 09:35 AM   #3
ksaudi
Thanks Ritchie
I assume these are identical on both models?
How much do you want?
Thanks
Keith
Old 04-01-11, 10:11 AM   #4
If no joy with Ritchie, try Mike on 07809 222346, he had a red one in for breaking, don't know if he still has it, worth a call( he js in Lockerbie)
Old 04-01-11, 11:13 PM   #5
sam
for your diff lock, check the pink pipe that goes from the inlet, along the bulkhead and behind the battery, chances are its split/cracked
Old 05-01-11, 12:11 PM   #6
ksaudi
Sam
Thanks for tip. I can see a small pinkish pipe (about 4 mm dia) behind and connected to right of battery but cannot see where it goes. Is that the one? No warning lights appear when Diff Lock button pressed but could pipe still be problem?
Keith
