Classic Audi » Technical » Mech/Tech » Transmission » B4 80 TDi box into B2 80 GL
Old 02-09-10, 03:13 PM   #1
markb
Default B4 80 TDi box into B2 80 GL
Following on from this thread: http://www.classic-audi.co.uk/forum/...ad.php?t=12456
I have now got a 1995 B4 80 TDi to transplant engine and 'box from.
The engine is already out and the gearbox is likely to be extracted tonight.
My question is, since I've never had a B2 box out, does anyone know how much work is involved in fitting this B4 box to my B2? will the mounts line up? are the driveshafts the same size? I know I will have to convert to hydraulic clutch and I am hoping to use/modify the B4 pedal box.
I'm sure I can overcome any problems, but I'm just after a quick heads up so I can better plan for it.
Many Thanks,
Mark.
markb is offline   Reply With Quote
Old 02-09-10, 04:27 PM   #2
JMLAudi
JMLAudi's Avatar
Default box changed
Hi Mark
You going to need part of the tdi pedal box as you got the throttle penetionter on it as well as master cylinder for clutch
I think its best if you try using pedal box assembly unless you good at fabrication
grab the front struts as well for hubs to use with driveshafts as flanges will be different to the tdi box
there are possibly more to worry about .....keep donor car for as long as possible incase you need to strip more
my 2 cents
cheers
john
best if you p
Old 02-09-10, 05:27 PM   #3
markb
Thanks for the advice John.
I'm converting the engine to use a mechanical pump so I won't need to retain the throttle pot, so some mods of the pedal box will be required.
If I have to change the front hubs it will end up being 4x108 rather than 4x100. Do you happen to know if there's a way to use the standard hubs? will the inner CVs swap between shafts?
Mark.
Old 02-09-10, 05:40 PM   #4
JMLAudi
JMLAudi's Avatar
HI Mark
if you using mechanical pump .........do you have one.............i got a pump not sure if 1.6 td or 1.9 td you can have it.even if used for spares
then only other reason why pedal box to be modified is if you use hydraulic clutch .cant help out there lol
If you using diesel gearboix the flanges are different to the set up you have nw.........if you can see if the driveshafts expecpt your outer cv joints and shafts same lentgh as your B2 ones you got it easy..............there are others here that could advise you on the number of spines on shaft and your joints
Good luck with change you have best of both worlds
cheers
john
Old 02-09-10, 06:00 PM   #5
markb
Yeah, I've already got a pump to use, it's from a land rover discovery. The 1.6/1.9TD pumps can be modified to work, but it takes a lot of work. You shouldn't give it away though, those pumps are always sought after! Thanks for the offer though!
I'll keep my fingers crossed on the CV joint issue.
I'll post my progress here or in a readers resto thread if i get round to making one later.
Old 02-09-10, 07:54 PM   #6
What's the reason to install TDI engine if biggest advantage is already lost when u install that mechanical pump?
