Classic Audi » Technical » Mech/Tech » Engine » Audi 100 turbo engine into non-turbo Audi 100
Old 15-04-08, 07:00 PM   #1
Default Audi 100 turbo engine into non-turbo Audi 100
Hi,
I have a 1990 Audi 100 2.3 quattro Avant which I really like, and drive everyday.
I have the chance to buy a 1990 Audi 100 Avant 2.2 turbo (same colour and everything I think), which is the 182BHP engine, but the owner has changed the ECU and apparently its no 200bhp or so.
If I have the complete car, how hard is it to transplant the engine, ECU and relevant wiring etc across?
The 100 turbo is 2WD, so I won't be using the gearbox.
Does the engine loom for my 2.3 non turbo engine just unplug from the fuse panel, and then plug the 100 turbo engine loom in?
It seems like too good an opportunity to miss....... especially as I will have a ready supply of spares...........
Steve
Old 15-04-08, 07:10 PM   #2
I would imagine the turbo has an ecu but not sure yours does. You will need to check.
Old 15-04-08, 07:24 PM   #3
The turbo does have an ecu, but if I have the whole car, can I unplug everything from the turbo model, and stick it into my non turbo model?
Old 15-04-08, 07:44 PM   #4
crisarc
Default re transplant
you could try tim at renntech for some advice? 07725544492,sounds like aplan though , good luck
Old 15-04-08, 08:54 PM   #5
Octanejunkie
Octanejunkie's Avatar
I imagine the engine itself would drop straight in.
As you probably suspect, its the wiring that'll cause the migraines. Having said that, its pretty old school so it might be quite straight forward. Theres an article in Practical Performance Car this month about a guy transplanting the engine from an Omega into a Scimitar. Apparently he ran the Omega and just snipped at wires till the engine stalled! An interesting approach to trial and error.
The best idea would be to remove everything right up to the fuse box, and perhaps even transplant that too. Compare it with your own, If they are the same just with different things missing or added, it may just be a plug and play affair, but be very gentle with all the electrics and take your time. Do you have another daily driver? It will take you about three times longer to complete the job than you originally anticipate! Make sure you fit a new clutch while everything is out, and have a good supply of gaskets. May even be prudent to do the cambelt and water pump too if theres no history for that.
Old 15-04-08, 09:13 PM   #6
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
All good points, but if you are going to do the cambelt while the engine is out, make sure you undo the crank bolt before you remove the engine its monster tight.
Ebay S4 S6 2.2 Turbo engine Audiden Parts For Sale 2 22-11-09 11:00 AM
VW T25 pickup with Audi turbo engine pimpdriver Cars For Sale 15 21-11-09 03:30 PM
90q + turbo engine stoop44rio Cars For Sale 11 17-09-09 07:51 PM
10 valve turbo engine crisarc Parts For Sale 9 26-01-08 07:49 AM
10valve turbo engine crisarc Parts For Sale 3 10-10-07 09:34 PM
