Classic Audi » Technical » Mech/Tech » Engine » Crankshaft Locking Tool - kv 2226
Old 05-03-08, 10:02 AM   #1
Drazic
Default Crankshaft Locking Tool - kv 2226
Morning Gents,
My mechanic requires the crakshaft locking tool i.e. the one that locks the pulley to undo the 27 mm bolt (280nm) to change the cambelt etc.
Anyone know where I maybe able to source borrow one? The local Audi dealerships have apparently lost theirs!!
Many thanks in advance
Doug
Drazic is offline   Reply With Quote
Old 05-03-08, 10:54 AM   #2
Audi do sell them about 25 quid. I hope your man knows his tools cause to undo that bolt with it's 380lb ft of torque it goes with a bloody bang I can tell you. Really need to ensure the locking tool is correctly inplace also as they can slip, then the guy holding the scaffolding bar ( cause that's what you need to undo it ) slips and spends two weeks with concussion. I had the job of sitting on the floor with my feet pushing on the end of the extension bar keeping it on the end of the bolt pulling on the bottom valance for stability. When the bolt went, I could have cried cause I thought the head had sheared. It hadn't but by God what a job..............Don't forget the loctite on the bolt after either.
Old 05-03-08, 11:15 AM   #3
audivw
where about are you ............. i have one here
and the correct touqe for the bolt is 350nm on a CQ and 350nm on a UR and if you don't have the other locking tool it's 450nm.
audivw is offline   Reply With Quote
Old 05-03-08, 11:47 AM   #4
Drazic
Thanks! I suspect it will probably be worthwhile and more cost effective to buy the tool to give to the garage whenever needed, but thanks nontheless. It all sounds very complicated to me!!
I have an Audi 90 quattro and they advised my mechanic that it was 280nm - have Audi got this wrong then?
Old 05-03-08, 06:06 PM   #5
audivw
Audi don't have it wrong your spanner man has.
i have checked and double checked it 450nm
the locking tool is 2084 if only useing this the toque IS 450nm
if useing 2079 & 2084 the touque is 350nm.
tell your spanner man to check & he'll find he's wrong and may end up oweing you a engine rebuild
Old 05-03-08, 06:34 PM   #6
Puglife
==>PUGSPORT!<==
Puglife's Avatar
it doesn't need to be that tight..... Thats overtightening imo.
A neighbour has a white CQ and has had it from new. He has done 155k in it and changed the cambelt twice so far himself, made his own locking tool and only retightens the bolt to 250nm. Never had any problems
Old 05-03-08, 12:30 PM   #7
I wasn't far off with 380 lb ft was I. Still a bast*rd to do.
Old 05-03-08, 01:00 PM   #8
Drazic
Sounds it! Any idea what the part number is so I can order one?
Old 05-03-08, 02:29 PM   #9
Baggee
Baggee's Avatar
You decided to keep her then Doug
Old 05-03-08, 11:45 AM   #10
Drazic
Thanks - I suspect it may well be worth buying one. With regards to knowing what he''s doing he is mk1 golf/jetta/vag etc specialist....www.mvdevelopments.co.uk SO in other words I bloody hope so!!
Thanks for the advice on the removal and reinstatement - tricks of the trade ey!!
strut top removal tool pimpdriver Suspension & Brakes 28 24-02-10 10:16 PM
central locking Micky Bodywork, glass & exterior fitments 6 07-08-09 02:52 PM
kv head bolt tool audicoupeparts Engine 2 11-02-09 05:52 PM
Central Locking Pump - '82 200 5E one trick phoney Electrical problems 6 25-09-08 02:52 PM
2226 Booty General Chat 17 05-03-08 08:33 PM
