Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Changing the front subframe bushes -easy or big job?
Old 24-09-19, 10:50 AM   #1
Modus
Default Changing the front subframe bushes -easy or big job?
The Front Subframe bushes are reportedly perished (the 2 main bushes that hold the front subframe in place) and we believe that is the likely source of a clunk when driving.
Does anyone know how you go about changing these bushes? i.e. is it a major job engine out or can you drop the subframe in some way to get at them? Any tips or info would be appreciated before we embark on what may be a big old job.
This is the bush:
431399151D
https://www.ebay.co.uk/itm/291825450393
and here's a diagram of where it sits:
https://audi.7zap.com/en/rdw/audi+20.../399-36000/#12
[item 12 on the diagram]
https://7zap.com/en/part/VAG/431399151D/
Modus is offline   Reply With Quote
Old 24-09-19, 04:50 PM   #2
moonwatcher
moonwatcher's Avatar
done in situ,
take the weight of the sub-frame on a trolley jack, loosen the bolt, slightly lower the jack to remove the bolt and the upper half of the bush, replace the bolt, jack the sub-frame back up, remove the fixing bolt and replace the lower half of the bush, refit the bolt.......and do the same on the other side
that should do it
Coupe Quattro 1985
Old 24-09-19, 05:47 PM   #3
431399151D
There's 4 bushes holding the subframe on??
Items 2 and 3 on the diagram?
Not sure how you'd go about doing them in place.
Old 24-09-19, 05:54 PM   #4
tractor Dave
They are a PITA to remove. Most burn them out. The OE bushes are also a pain to press back in without damaging. Poly bush are much easier to fit.
Old 24-09-19, 06:09 PM   #5
Groundhog
Just to clarify, the ‘bushes’ you link to on e-bay and in the schematic diagram is an engine mount not a sub frame bush! Which is it that you are replacing?
Groundhog is offline   Reply With Quote
Old 24-09-19, 06:56 PM   #6
Duffy3074
I did all 4 of mine but did it on the bench with a vice, under those circumstances it’s straightforward
Removing the subframe is essentially just 6 bolts (once the cars up on stands and the wheels are off) plus whatever ARB links you have
Edit: your engine mounts off of yours, disregard all that I said!
Old 24-09-19, 07:53 PM   #7
Groundhog
...........sorry meant gearbox mounts not engine mounts.
Old 26-09-19, 08:03 PM   #8
Adam G
I have done front and rear Subframe bushes recently, the biggest pain was having a bolt snap on both during removal. A nightmare to drill out.
It might be worth pulling the rubber grommets out of the body just above the bushes and squinting some release fluid down there onto the threads and the lock nut. If you have freeze spray try that on the bolts too.
Sent from my F5121 using Tapatalk
Adam G is offline   Reply With Quote
Old 01-10-19, 04:44 PM   #9
Modus
Thanks v much for all the advice which is a Massive help.
The car is indeed an Audi 200 Quattro
Can anyone confirm off the Exploded Parts Diagram which item is actually the subframe bush, please?:
https://audi.7zap.com/en/rdw/audi+20...3/3/399-36000/
Old 01-10-19, 05:11 PM   #10
tractor Dave
2 and 3. Front/rear are different.
12 is the gearbox bushes.
