Members: 43,065 | Total Threads: 40,086 | Total Posts: 471,053 Currently Active Users: 17178 (3 members and 17175 guests) Welcome to our newest member, JimmyAnype |
Helooo, anothere weird one. Potentially dangerous - toyota may be bought within weeks (serious measure to take/because I know once I do that I'll lose all interest in cars)
Only has happened two or three times, only when warming up/while bomb pressure is building. Press the brake pedal..... And you lose power steering. (peesosheeet!!)No idea on this one, but was just driving round there, checking on sites/flooding, turned right across the oncoming traffic(well there isn't any here, but crossed that lane) pressed the brake pedal, brakes work like new, lost power steering, and just about parked the car in a rockery/flower bed. ![]() Come off the brake pedal for even a second and the power steering returns. Every component is good, the only thing I can think of is the filters inside the banjos which attach the hydraulic lines to the pump. I cleaned the brake/bomb banjo filter while fitting the new bomb. Haven't cleaned the power steering banjo filters, so presuming they are dirty and the bomb circuit is taking priority?! That's the only thing I can think of. Any other ideas? Buy a Toyota? ![]() Last edited by missfire; 26-01-14 at 11:09 AM. |
Dump the abs all together go for servo
The brake booster circuit is separated from steering circuit. 6 pistons supply the steering rack, two are for the pressure accumulator.
Are you sure, that everything is fine? Bomb pressure should never decrease significantly within a few days. May be the bomb is worn? Also the brake booster might be leaking, causing a lack of oil pressure. You need to check / clean the filters of all banjos and the filter in the filter inside the reservoir (if present) as well. Check brake booster for leaks. |
#4 | |
It doesn't have ABS, and it already has a servo, but I know what you mean..
set up a vacuum servo you mean. Yes, good option, but easier to buy a Toyota. Quote:
I'm not sure what's going on, the bomb gives you about 30 assisted brake pedal applications before running out, it still works the next day before the engine is switched on. There was a tiny amount of some kind of oily stuff showing up on the road the other day when the rain was washing the road. I always blame the post man, because his gearbox or sump is leaking oil at a horrible rate! My rear crankshaft seal is leaking, you can see oil around the clutch bell housing. I'll look for leaks TOYOTA! (Joking) |
Did it lose assistance as in you could still turn the now heavy steering wheel or did it lock up? was there any noise at that moment?
1992 80 quattro 20vt |
It could have locked! I'm not sure, if it wasn't locked it was incredibly difficult to turn, much, much harder than the little 80 I just had which had no power steering.
There has been a weird clunking noise while doing three point turns from the top of the driver's side strut tower. Maybe the bearing is locking?! Needs attention whatever it is! |
i've felt something similar with the ur; such a long time ago, though.
Over a period of time, the brake circuit was slowly overhauled, but there was no specific reason/cause determined at the time, and it hasn't happened since in about 16years. The experts simply denied that it was possible- but it felt like the rack locked, not just lost assistance.
A silly one, check the condition of the lower balljoints. Make sure there is no play in them. Also lift the rubber boot and see if they are dry and red rusty with no grease left.
We have had exactly this recently on a cabriolet and it turned out to be the balljoints. No play but rusty and seizing not allowing the steering to turn Tonks4x4 - The Land Rover Specialist
http://www.tonks4x4.com |
Will do! I haven't changed them but it did go through an MOT just a couple of months ago, not saying much maybe
but I will look!Micky.. I drive a pink 100 avant, smashed in right up one side. Would I do that if I cared what other people think? ![]() |
[/quote]yes because its still better than driving around in a toy-car ![]() |
