Classic Audi » Technical » Mech/Tech » Interior » Headliner remove and refit
Old 10-11-09, 05:48 PM   #1
vag80
vag80's Avatar
Default Headliner remove and refit
Has anyone removed the headliner from an 80 TYPE 81? as i have to remove mine to do some work on the roof, and then refit it
200k club member
87-b3 80
83-4000 2 door
Old 10-11-09, 06:58 PM   #2
Removed some typ 85 ones
Old 10-11-09, 07:03 PM   #3
vag80
vag80's Avatar
wot sort of job is it? are they glued on and do you have to remove all the windows
200k club member
87-b3 80
83-4000 2 door
Old 10-11-09, 07:18 PM   #4
If they are the same as the typ 85 they are not glued on but you do need to remove the handle pulls (2 screws on either side IIRC) and they are on poppers so be gentle.......do you have a sunroof?
Old 10-11-09, 07:42 PM   #5
vag80
vag80's Avatar
no sun roof, did remove door seal the end seam to be glued under the rubber (bummer)
200k club member
87-b3 80
83-4000 2 door
Old 10-11-09, 07:55 PM   #6
Hmmm it is glued on by the doors if you go gently you can prise it off with a small screw driver...........dont rush it or you will rip it Thats why I asked if you had a sunroof cos it is glued on there as well but the actual roof isnt glued just held by poppers
Old 10-11-09, 07:58 PM   #7
vag80
vag80's Avatar
cheers for that will have a go tomorrow
200k club member
87-b3 80
83-4000 2 door
Old 10-11-09, 09:35 PM   #8
kully
kully's Avatar
Be a good idea to warm it up really well first. should make it easier
how to remove aux guages in a coupe c9eag Interior 11 21-11-09 06:22 PM
Trying to remove kv to fit aby quattropower Engine 0 27-03-09 09:23 PM
