Classic Audi » Technical » Mech/Tech » Engine » quick one!
Old 09-10-09, 03:42 PM   #1
andy
andy's Avatar
Default quick one!
what is the ID of the hose coming from the fuel pumpto the tank on an '88 WR??? as the final face of the swirl pot is going on in the morning.
thanks,
Andy
Old 09-10-09, 03:52 PM   #2
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
Before or after the plastic fuel filter..
Old 09-10-09, 03:58 PM   #3
andy
andy's Avatar
hmmm, havent looked, but the part which goes into the tank, just underneath the tank i guess,
need to machine a piece for the hose to fit over
Old 09-10-09, 04:04 PM   #4
Audi Derek
Audi Derek's Avatar
You have two that go into the tank one is a return and one is a feed...
Old 09-10-09, 04:07 PM   #5
Audi Derek
Audi Derek's Avatar
Here are some pics of the tank in the back of my CQ..
Old 09-10-09, 04:08 PM   #6
andy
andy's Avatar
oh bugger! i knew i needed to take the tank out to see but i was assured there was just one outlet underneath, unless, is the return the one near the top of the tank??
So Far i have a tank with fuel guage hole, fuel inlet, 3 ports to the swirl pot, and one to replace the small nipple at the top.
3 inlet ports into the swirl pot, about to make a nipple for outlet, am i Missing anything?
much apreciated
Old 09-10-09, 04:11 PM   #7
andy
andy's Avatar
just using one fuel pump on mine by the way, gravity fed swirl pot ( i think you suggested this??)
much less serious bit of kit compared to yours, looks brilliant!
Old 09-10-09, 04:15 PM   #8
Audi Derek
Audi Derek's Avatar
Yes I still have not taken any with the swirl pot as of yet, but it sits just to the left of the battery..
You have to remember that you have to have a return pipe back to the tank the one on the top is the breather..
Old 09-10-09, 04:19 PM   #9
andy
andy's Avatar
thanks, so on an origonal tank, there is two ports underneath (outlet and return)??
If i'm right can you tell me what the ID is of the hoses? so i can make the new nipples.
cheers
Old 09-10-09, 04:32 PM   #10
Audi Derek
Audi Derek's Avatar
Heres the new set up with swirl pot..
I used 10m breaded high preasure fuel pipe and for the feed pipes to the pumps that was from memory 15m high preasure fuel pipe..
Quick Poll stuartmmcfc General Chat 22 28-01-10 03:07 PM
Quick Q: What does this do? moomin Electrical problems 12 05-09-08 11:22 PM
