Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Brake Cylinder FAG 31
Old 21-08-09, 06:32 PM   #1
rishik
Default Brake Cylinder FAG 31
I am trying to replace the wheel brake cylinders on a 1986 Audi 80 1.8 (Carb) GL. I am pretty sure its the series 2 (the one before the new model was also launched in 1986). But I am so confused, everything I look at points to them being 14.3mm bore, however when I called the shop with my reg they said it was a 15.9mm!? All thats written on them is FAG 31, and as they are still in the car I can't measure before buying. The rubber covers have these numbers 331611695 and R1759.
My next question, does anyone know the size of the bolt that connects the brake line into the cylinder - I've been trying a 11mm spanner but it seems to be stripping the bolt; is it imperial?
Thanks so much for reading - I am totally confused, and any advice would be greatly appreciated!
rishik is offline   Reply With Quote
Old 21-08-09, 06:45 PM   #2
vag80
vag80's Avatar
you my need to buy a proper brake spanner so you don't round the nut off you'll have to have apipe made
200k club member
87-b3 80
83-4000 2 door
Old 22-08-09, 05:34 PM   #3
rishik
cheers mate, i've resided myself to using mole grips as i got hold of some 11mm brake spanners and they didn't seem do the job. am tempted to just take the whole car to the garage and get the work done instead :-(
missing a Cylinder? :( Gaz Engine 20 29-03-09 12:18 AM
Audi 80 B2 1985 brake master cylinder Octanejunkie Parts Wanted 2 29-07-08 08:22 AM
5 cylinder TT ??? slacky General Chat 2 07-07-08 04:54 PM
WR cylinder head need kesfi Parts Wanted 2 10-04-08 12:19 PM
Master brake cylinder - Auto & Manual - any difference? randall977 Suspension & Brakes 0 03-12-07 04:40 PM
