Classic Audi » Community » General Chat » Where's me MAF Sensor.???
Old 24-07-09, 10:30 AM   #1
Default Where's me MAF Sensor.???
Anyone point me in the general direction of where my MAF Sensor is on the S6? Probably could do with a clean as I believe they get dirty and suffer as a result. Don't know me way around this 20vt lump yet too well!
Old 24-07-09, 10:44 AM   #2
vag80
vag80's Avatar
most maf sensors are on the air in take pipe from the air box they are a hard plastic and have a multi plug going to it, you have to be very carefull cleaning them as they damage very easy
200k club member
87-b3 80
83-4000 2 door
Old 24-07-09, 10:44 AM   #3
20vcqdriver
20vcqdriver's Avatar
See pic, though it is a very fine wire and should not need cleaning as the unit has a burn off facility that on switching off heats the wire to red hot to burn off any contaminants. What makes you think there is a problem.
File Type: jpg Pic 58p (300bhp 20Vt Install complete).jpg (105.7 KB, 9 views)
Old 24-07-09, 10:49 AM   #4
Just something I read on the S2 forum. If it doesn't need it then I wont bother but Im just don't know me way around a 20 valve turbo lump that well. I can turn a KV inside out now and upside down!
Old 24-07-09, 11:10 AM   #5
4v6
As per 20vcq's instructions, these dont need cleaning richard, they do it themselves.
The ecu momentarily increases current flow through the wire at startup to burn off any contaminants.
The only thing you can really do is ensure theres no leaves blocking it or suchlike.
Kv's exactly the same ( near enough) from the head down matey so youre half way there!
Old 24-07-09, 12:45 PM   #6
20vcqdriver
Yep agree there, didn't take me long to get my head round it....Having lots of problems to rectify also speeds up the process..
Digital Camera Sensor cleaning... Isimmo General Chat 0 03-10-09 01:33 PM
ABS Sensor Caps Isimmo Suspension & Brakes 3 24-09-09 09:58 AM
Wheres the oil pressure sensor? djb1607 Engine 2 13-08-09 11:35 PM
Lamba Sensor - Silly question krzracingcouk Engine 2 30-11-07 06:15 PM
Oil Temperature Sensor krzracingcouk Parts Wanted 7 20-11-07 03:47 PM
