Classic Audi » Technical » Mech/Tech » Transmission » 6 speed transplant: upgrade or nonsense?
Old 07-07-09, 08:19 AM   #1
FlyingDutchman
Just do it!
FlyingDutchman's Avatar
Red face 6 speed transplant: upgrade or nonsense?
I am making up a list (with a life of it's own) of things to do on my 1993 Audi 80 2.0 16v, as I believe in upgrading parts, not just replacing. This of course, makes life interesting to the point of madness..at times. I sense a lot of Audi fanatics experience the same, though.
Nonetheless, I have a question (1st of many).
Will the 6 speed gearbox fit my car? If so, where is the difference in gear ratios, from 1st through the whole range? What could the effect be performance / economy-wise?
(Sorry, it always starts with just 1 question...)
FlyingDutchman is offline   Reply With Quote
Old 07-07-09, 12:16 PM   #2
20vcqdriver
20vcqdriver's Avatar
Not sure with the 4 cylinder engines! If the block is the same as the later 4 cylinders you have a possiblity of doing this, but not sure.
Have all the info necessary if it was a 5 cylinder...
Old 07-07-09, 12:26 PM   #3
can't really see the advantages of fitting a 6 speed box to the 2.0l engine?
Old 07-07-09, 05:41 PM   #4
FlyingDutchman
Just do it!
To be honest, after reading some feedback, neither am I, unless the power plant is upgraded as well, as some mentioned. Time to rethink!
Old 07-07-09, 05:45 PM   #5
FlyingDutchman
Just do it!
Thank you, I will do some more homework on this, it seems as if I will have to rethink process and change powerplant to really get the benefit. I will keep you in mind should I stumble upon a 5 cylinder, which seems to be very popular and full of grunt!
Enjoy.
Old 07-07-09, 05:53 PM   #6
Unless it's the 20v or 20v turbo lump (S2/S2 avant), then you'll find the 2.0 16v engine on a similar par performance wise with the earlier 2.2 or 2309 5 cylinder 10v engines.
You just don't get the same grunt with a 4 cylinder engine though! Although a decent exhaust system would help that a little!
in fact, your engine should be 135hp and the 10v 5 cyl engines are 134hp.
Old 08-07-09, 09:10 AM   #7
FlyingDutchman
Just do it!
Thanks, at least the collected info confirms that all of you are in the same line of thought, I have learned more in 3 days than in the same number of years with my GTX'es. The bigger engine=more grunt makes sense.
Much appreciated!
Old 08-07-09, 09:14 AM   #8
The other choice is look at a more modern engine implant. Not sure how easy as I've not seen it done, but a 1.8T lump would always be a good talking point at the pub!
let alone the 2.7 biturbo V6 lump!
Old 08-07-09, 05:51 PM   #9
vag80
vag80's Avatar
an 1.8t will fit in there easly,i think even a v8 may fit as the engine bay in the b3 and b4 is big
200k club member
87-b3 80
83-4000 2 door
Old 08-07-09, 06:55 PM   #10
ChrisG
ChrisG's Avatar
several V8 conversions done in Europe, I've seen pictures ( a dark green series 4 comes to mind)
V8 into B2 4000 quattros in the USA.......silver one on Audiworld with loads of piccies of the various stages........ cannot find the piccies now I looked many months ago and they seem to have gone
80q 1.8 K-jet upgrade? 5-E Engine 7 13-11-09 01:19 PM
Engine transplant Tim C General Chat 0 30-10-09 06:05 PM
CQ Brake upgrade? Gaz Suspension & Brakes 5 27-09-09 04:34 PM
80/90 quattro transplant 10v turbo moggies Engine 8 26-03-09 06:51 PM
