Classic Audi » Classifieds section » Parts Wanted » Audi 100 clutch pedal needed.
Old 13-04-09, 09:20 AM   #1
Lankytim
Lankytim's Avatar
Default Audi 100 clutch pedal needed.
Cable type, for my 100 avant. Would consider whole pedal box. HELP!
Old 13-04-09, 02:30 PM   #2
BigT80
Hi, Do you know if it is common to other models of that period or unique to the 100? Cheers. G.
Old 13-04-09, 07:44 PM   #3
Lankytim
Lankytim's Avatar
No idea im afraid, im ringing Audi tomorrow, theyl beable to tell me if its common to other models. Hopefully theyl say they have one in stock for £10!... possibly.
Old 13-04-09, 08:34 PM   #4
BigT80
If same as 80 of that period, then I removed the pedal box from my 80 Sport before I scrapped it. May also have one from a 87 coupe. Just a question of where! Sounds like it's fairly urgent; else could drop it off with space-saver on the 1st. Let us know how it goes. Cheers. G.
Old 16-04-09, 03:23 PM   #5
eltee
eltee's Avatar
448721315 £44.48 +VAT, only fits audi 100/200
chacked ETKA and not fitted to any other model.
did you get this sorted?
eltee
88 100 cs sport
Old 17-04-09, 04:17 PM   #6
Lankytim
Lankytim's Avatar
Not sorted yet. I rang Audi and they wanted £45 odd for it with a 10 day wait for delivery. Theres a manual A100 in the local breakers ao im going to raid it when I get chance.
Old 17-04-09, 05:10 PM   #7
b2_sport
b2_sport's Avatar
Give me your registeration number & your looking for a pedal box or a clutch pedal? I can ask the parts guy where I work if we have this in stock.
cheers
Old 17-04-09, 05:55 PM   #8
Lankytim
Lankytim's Avatar
Im after just the clutch pedal and my reg is C849 MTY....
Old 18-04-09, 06:26 PM   #9
Lankytim
Lankytim's Avatar
UPDATE.
I found a pedal in the local breakers, fitted it today but when I tried it out I found the clutch was solid. Im guessing the clutch/clutch yoke/ release bearing has failed in a way that makes it impossible to depress the pedal but the enthusiastic "pumping" of the clutch pedal in a vain attempt to find a gear has caused the pedal to fail.
Its all back together again now.... I just need to source/fit a clutch now. Im that fed up I may get someone else to fit it. I frigging hate doing clutches.
Ebay ATE-Clutch-Master-Cylinder-To-Fit-Audi-100-200-Quattro BIGGYIN Parts For Sale 0 26-11-09 08:01 PM
S6 Accelerator pedal. Booty Technical Info 5 31-07-09 09:35 AM
hard brake pedal damianshep Suspension & Brakes 7 29-04-09 07:08 PM
Clutch help needed ASAP Scarlet Transmission 3 13-11-08 03:53 PM
Audi 100 2.8 clutch joe90 Transmission 0 11-10-08 03:22 PM
