Classic Audi » Technical » Technical Info » Core Plug Set - B2 five pot
Old 18-02-09, 05:28 PM   #1
BigT80
Default Core Plug Set - B2 five pot
Hello. Doubt if there is much call for these, but 'my' - well I was supposed to pick it up today - '83 80CD blew a core plug out during this last cold spell.
Does anyone know if you can get a set of these, or will a universal set do the job? At least the block does not seem to be cracked & it's the one by the starter motor, so can be got at fairly easily. Any help appreciated. Thanks.
BigT80 is offline   Reply With Quote
Old 18-02-09, 05:37 PM   #2
4v6
I can get these from my local supplier.
Apparently theyre all the same size, they got me the ones for Ralf and for the 1B, not very much , couple of quid iirc.
Old 18-02-09, 08:26 PM   #3
BigT80
OK, thanks for the info: sounds like a part that's easy to get & cheap for a change - I'll have a ring around tomorrow. Cheers.
Old 18-02-09, 09:04 PM   #4
4v6
If you get stuck, pipe up ill get a couple from the local supplier when im over there tomorrow anyway just in case.
Old 06-03-09, 11:15 AM   #5
BigT80
Hello 4V6. Putting up my posting on the new purchase reminded me that I did not say thanks for picking up a couple of core plugs, but as you can tell I did manage to get one from local supplier as you suggested I might. 89p +VAT. If only the fitting time was in proportion to the cost Cheers for your help.
Old 06-03-09, 11:40 AM   #6
4v6
No worries matey, theyre a bit of a pain to change if the engines in situ, consolation is theyre nice and cheap.
Have fun there.
spark plug gaps/ tolerances quattrokid Engine 12 20-01-10 04:55 PM
Core plug sizes Budgie Technical Info 5 20-08-09 08:57 AM
