Classic Audi » Technical » Mech/Tech » Transmission » outer cv size help needed
Old 16-04-18, 10:57 PM   #1
boomsly
Default outer cv size help needed
hello all,
another question just trying to confirm if b3/4 80 v6 quattro front driveshafts have the larger 82mm wheel bearing meaning larger front cv's,
had a good google but no access to anything that may help or solve the problem,just to add parts stores say 82mm and some say might have 75mm
cheers
boomsly is offline   Reply With Quote
Old 16-04-18, 11:22 PM   #2
According to catalogue 82 mm bearings should be on all V6'es - I'm personally 100% sure about 2.8.
Old 17-04-18, 07:50 AM   #3
boomsly
so 1992 2.8 quattro v6 aah engine code ones should be 82mm as i suspected
what catalogue did you use as i managed to get onto etka but not found any sizes unless im using it wrong
many thanks !
Old 17-04-18, 09:35 AM   #4
Apparently you're using it wrong, as there are sizes mentioned.
Old 17-04-18, 10:42 AM   #5
boomsly
wouldnt surprise me lol ill look again cheers
