Classic Audi » Technical » Mech/Tech » Wheels & Tyres » How to adjust camber on UR
Old 06-08-17, 03:00 PM   #1
jossdawn
Default How to adjust camber on UR
Hi after kerbing my rear wheel I cannot get the camber to line up verticaly can anyone advise
jossdawn is offline   Reply With Quote
Old 06-08-17, 03:12 PM   #2
quattrodave
Its possible to adjust camber by moving the ball joint relative to the wishbone ( 2 bolts to loosen you can then slide the balljoint towards or away from the wishbone), you will also need to adjust the rear track if you adjust the camber as it will alter the relative alighment.
You must have bent something if its changed so B4 adjusting anything you need to check for subframe/wishbone/lower strut damage.
