Members: 43,028 | Total Threads: 40,085 | Total Posts: 471,031 Currently Active Users: 643 (2 members and 641 guests) Welcome to our newest member, Esmeraldosrfu |
As above, i'm trying to undo the cars original hard brake lines on the S6 saloon to change the flexi hoses and they're rock solid. Ive so far tried freezing them and can slightly turn the 11mm nut on the brake line but it's twisting the brake line also.
This has happened on both sides at the rear. I have spare perfect lines removed from the 2.8 quattro donor car but have just realised if i'm going to replace all the rear lines to just under where the rear seat is i'll have to remove the fuel tank. Thats a big no no as the car is on the road and i can't move it. Can anyone suggest a way around this problem? Pic of what i'm talking about. ![]() Last edited by vorsprung durch technik; 27-10-17 at 05:54 PM. |
You need a spanner on the rear hex to stop it turning, get yourself a couple of brake spanners to do it easier.
Here til thursday, enjoy the veal etc etc... ![]() |
#3 | |
Been doing that all along but the hard line just twists and feels like it will just keep twisting until it breaks. I've got a brake spanner. |
Chop through the clip and use a grinder on the braided line metal part if you don't care about it
Remove the assembly through the hole (there should be enough flex in the hard line). Lots of heat should be enough to undo it or use a dremel to cut a groove in the remains of the ferrule which will allow the brake nut on the hard line to be undone
#5 | |
Are you saying i should just heat up the hardline where the nut is to free this off? |
If all the above fails, or as an alternative, you could cut the hard line in a suitable place, fit a female union and flare the pipe. Then make up a new male-male pipe to replace the section you cut out.
Hope you get it sorted
Just heat the complete assembly - just be careful as brake fluid is flammable
Many thanks chaps, all very much appreciated, as this bunny hasn't had this problem before.
I assume you have tried Plusgas Formula A?
![]() I buy it in 2 litre tins and top up my little 250ml applicator tin; one of my bus club friends buys it in 5 litre tins! ![]() |
Yep been using plusgas formula A.
My tin of eBay has already lost it's pressure after only been used a couple times. |
