Members: 19,815 | Total Threads: 40,093 | Total Posts: 471,108 Currently Active Users: 15547 (5 members and 15542 guests) Welcome to our newest member, Darrin#[Owitipitdrnyjipo, |
hi again. audi 200 quattro . have fuel pump working. but car will still not fire up no spark at plugs? no life at ht lead? have checked for broken wires etc. but at a loss now as where to go from here. regards bart. ecu ? ignition control unit? this car was so reliable once?
are you getting a spark from the coil ?
If not it may be the coil itself
Check to see if you are getting spark from king lead from coil if not check wiring to coil,if you are getting spark from king lead it could be rotor arm or could be fault with dizzy drive broken.If you remove dizzy cap can you turn rotor arm by hand?
| electrical gremlins? | Gaz | Electrical problems | 3 | 19-11-09 06:38 PM |
| concert radio volume fault | stoop44rio | In-Car entertainment | 6 | 22-09-09 10:14 PM |
| Another lighting fault? | stephen2320 | Electrical problems | 3 | 28-06-09 06:49 PM |
| electrical fault | bart simpson | Electrical problems | 3 | 17-02-09 09:08 PM |
| Fault codes | vag80 | Engine | 2 | 12-01-09 02:24 PM |
