Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Help required for rear brake discs
Old 13-11-16, 07:11 PM   #1
Gunga
Default Help required for rear brake discs
Hi, I'm new at this so here goes, iv got an Audi 1oo 2.2e auto 89 on a F plate.
I need a set of rear brake discs for it, I took it to my local garage and they can't get the right ones, so I took it to Audi main dealer and they cant get them either no longer available and no stock in Germany!! The problem seems to be the thickness.
As I understand it I need 245mm - 68mm - 51.9mm or
245mm - 67mm - 145mm depending on the way you measure them, oh on a 4 stud.
I was advised by Audi to contact this site and they were sure someone would put me in the right direction. Thank you Gunga
Gunga is offline   Reply With Quote
Old 13-11-16, 09:15 PM   #2
Andy10v
Andy10v's Avatar
From 7zap;
443 615 601 E brake disc 245X10 4/108
Try sticking the part No. into google, ebay.co.uk, ebay.de etc (just double check the dimensions listed)
2005 350z GT
Sold-1993 ABY coupe
Old 13-11-16, 09:23 PM   #3
Hanuman
Hanuman's Avatar
443 615 601 E? Maybe, possibly?
http://www.ebcbrakeshop.co.uk/files_ebc.v1
Old 13-11-16, 09:46 PM   #4
quattrodave
In stock and you can mail order them from here:
http://brakeparts.co.uk/#!/shop/AUDI...0Drums/BDS4343
Old 14-11-16, 09:16 PM   #5
Gunga
Hi, Thank you very much for your help, iv ordered a set of discs this evening so hopefully all will be well ill keep you informed!! but really thanks for help. Gaz
