Members: 43,020 | Total Threads: 40,083 | Total Posts: 471,016 Currently Active Users: 6836 (3 members and 6833 guests) Welcome to our newest member, Documentyjh |
The other day I changed my cam cover gasket. Not a huge job but now there is a very irregular miss fire and it will cut out for a split second. It is worse when the cafe is up to temperature. I've checked the timing and that is spot on. The plugs and ht leads are just a few weeks old and fine. I've checked all the connections of all the bits I had to disconnect and all seams OK. The throttle body is clean. My thoughts vould be leaning towards a fuel problem. Any thoughts from you guys?
It's a 90q 7A engine by the way.
This would be a stab in the dark of night, just give us a clue may be model and cc and if you can engine number.
if it's an ignition cut, check the inlet manifold grounds and that the MAF connector is fully plugged in
Sorted. I was the manifold earth connections. I had somehow only connected one and the other as making an intermittent contact on the manifold. Hence the missfire.
My kind of trick
