Members: 19,751 | Total Threads: 40,088 | Total Posts: 471,064 Currently Active Users: 1988 (0 members and 1988 guests) Welcome to our newest member, Esmeraldosxmx |
Hi folks,
I look to have some play in the rear control arms (pictured below) on my C4Q. Audi are quoting me nearly €400 for replacements which sounds odd, think they have quoted me for the complete arms or housing on the hub or something, just checking with them. Anyone else come across this? I am guessing it is just the rod ends I need. Picture is at: http://www.classic-audi.co.uk/forum/...pictureid=8630 For some reason it will not embed.
Mark 95 A6Q 2.8 12v 06 A4Q SLine 3.0 TDI _____ 88 90 2.0 (Pastures new) 96 UrS6 (Pastures new) 89 90Q 20v (Dead) 89 Coupe 2.2 (Pastures new) 99 A4 2.5 TDI (Pastures new) 95 80 TDI (Pastures new) |
The arm is readily available on eBay, via Germany, at sensible prices. Each side is about fifteen minutes to replace, if you have the tools. You might get the individual ends from Audi (though I doubt it), but the complete arm from a parts supplier is cheaper.
Audi might be quoting you to supply and replace, adjust. Their own supplied part is significantly more expensive. Technically, you'd need alignment, too. However! If you measure the length, centre to centre, of the old arm, and adjust the new one before fitting, you'll be fairly close. The arms are in 3 main parts. The ball end, bush end, and turnbuckle. The two ends keyed inside the turnbuckle- they are each machined with a flat through half of the rod that then effectively locks the two ends and prevents them from rotating, and sets the angle of the ball joint with respect to the axle. It'll make sense when you have one apart. I think I replaced a pair for less than €250, delivered. ![]() stabilizer / connecting link / 1 443505351P track control arm left upper / (1) 443505352P track control arm right upper / 2 443505365D ball head left inner / (2) 443505366D ball head right inner / 3 N 10218704 hexagonal nut M14X1,5 / 4 N 0111136 hexagonal nut BM14X1,5LH / 5 443505153B ball head outer / 6 N 0401814 hexagonal head bolt M16X1,5X105 / 7 N 0411817 hexagonal nut M16X1,5 / 8 N 0411835 hexagon nut, self-locking M14X1,5 / Getting cheaper! Although, there are a great many manufacturers and sources. These- http://www.ebay.co.uk/itm/REAR-CONTR...EAAOxy-WxTFlx4 I've also had some from Eurocarparts in the past.
I wish they would keep the damned Chinese away now that I can go home, so that I can enjoy Fish amok and a draught Angkor Last edited by Hanuman; 02-12-15 at 04:35 PM. |
Febi do them,£28+vat each
These are handed by the way,many people think they aren't |
I wouldn't be surprise if that price they quoted you is just for the control arms as i asked audi for the big bush that bolts to the floor pan and takes the long end of the lower arm and they wanted £400 for the pair thats 564 euros!
Hi, Spink. What's your source of the Febi items? With 4 chassis to maintain, I like that price
Andrew page (Camberley auto factors they also own)
That's my trade price but won't be much more over the counter I can get you them and send them if you struggle |
You guys are complete and utter heroes. I will keep you updated as I go. Huge thanks again
