Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Water inside cabin... but where from?
Old 21-01-09, 03:50 PM   #1
Lankytim
Lankytim's Avatar
Default Water inside cabin... but where from?
The passenger side front carpet in my Audi 100 is constantly wet, im trying to track down where the water is coming in from but does anyone know if its a commen fault with these models?
Im fed up of scraping ice from the INSIDE of the screen!
Old 21-01-09, 04:00 PM   #2
poopcoupe
21 + 19 = OLD!
poopcoupe's Avatar
I had the same problem with My coupe on the passenger side. I couldnt figure it out? Then I suddenly relised that everytime I jet wash the car it got in through a dodgy door seal!!! Dont jet wash.
audiless...........
Old 21-01-09, 04:00 PM   #3
with a ur its generally where the bonnet pull goes through the bulkhead so may be the same avenue to persue
Old 21-01-09, 04:01 PM   #4
Tarka
German Language Assistant
Tarka's Avatar
Could be a couple of things.
The first and simplest place to check is the plastic membrane that sits between the door metal and the interior door cards. Whip off the door card and see if the membrane is damaged or peeling away from the metal part of the door. It can even be the drain holes at the bottom of the door being blocked.
Other than that it could be a sign of a knackered heater matrix - more involving to fix to be honest.
1976 Audi 80 L - Sleeping
1977 Audi 80 GLS - W.I.P
1991 Golf Mk2 VR6 Supercharged
2003 Audi A6 Allroad - Daily
Tarka is offline   Reply With Quote
Old 21-01-09, 06:34 PM   #5
maynd
maynd's Avatar
I have the exact same problem, passenger side carpet wet when it rains a lot, but when i go to jet wash no water, only in the trunk because of a rear light bad sealed.
Anyone have a clue about the passeger side water?
maynd is offline   Reply With Quote
Old 21-01-09, 07:01 PM   #6
Puglife
==>PUGSPORT!<==
Puglife's Avatar
sunroof drains blocked or door window seals leaking allowing water inside the door.... I have soaking carpet and it originates from halfway up the Apillar (you can tell by lifting carpet and seeing where the sound deadening is wet up to).
Old 21-01-09, 07:33 PM   #7
Lankytim
Lankytim's Avatar
Thanks, lots of leads there! Its deffo not the sunroof though, as it hasnt got one.
The door seals sounds interesting. The passenger doors have had a scrape at some point and have filler at the bottom. Ill have to check to see if the drain holes have been obstructed.
Old 28-01-09, 09:59 PM   #8
qwerty2112
qwerty2112's Avatar
try sealing around windscreen rubber/ aperture, using grease in an old mastic tube. forcing nozzle under rubber and filling with grease. worked on my ur and gti. or try moving striker plate in on door so door closese tighter on door.
qwerty2112 is offline   Reply With Quote
Old 29-01-09, 08:57 PM   #9
MikeNZ
Often after accident repair on the door skin the clear plastic membrane behind the door card is not replaced by the panelbeater and water comes in (it normally flows through the door when it rains and out the drain holes - the clear plastic membrane stuck to the inside of the door metal is the only thing stopping the door card and carpet getting wet). Even if still present it seems to shrink over time and split. Use new plastic sheet and gaffer tape or RTV sealant to patch or replace, and make sure that it is sealed all the way around. I have had to fix this on 3 1980s Audis I have owned.
Old 29-01-09, 10:14 PM   #10
one trick phoney
one trick phoney's Avatar
Check around/in front of Battery - if ever a previous battery has been allowed to 'leak' it may have eaten through either gromits and/or body work.
Audi 200 5E
Subaru Forester XT
On-One Inbred 456
one trick phoney is offline   Reply With Quote
Water Mess! ian20v General Chat 6 19-11-09 10:49 PM
The temperature inside your car?? Coxy General Chat 16 09-11-09 11:43 PM
Water Splash Isimmo General Chat 2 14-10-09 12:27 PM
water ingress quattrokid General Chat 28 10-05-09 09:55 PM
Water in Coupe GT ZermattGT Bodywork, glass & exterior fitments 16 01-05-09 09:07 PM
