Classic Audi » Technical » Mech/Tech » Engine » N/a 20v non starter
Old 30-06-15, 07:05 PM   #1
audicoupeparts
Default N/a 20v non starter
Latest acquisition.
Turns over fine, won't start
Place I bought it from said it started then cut out
I'm thinking fuel pump
Changed relay for known good one
Does 10v pump straight swap?
I've a good one here I could try
Not had time check spark etc but will go through usual suspects!
Old 01-07-15, 07:09 AM   #2
pump should prime for a couple of seconds when the ignition is turned on.
If you cant hear that, then either the pump is faulty or the pump isn't getting 12v - fuse or relay normally
1991 90 quattro
Old 02-07-15, 04:36 PM   #3
quattrodave
Check the distributor just in case the gear has snapped thats what killed mine on one occassion, if not the 10v pump is direct fit for testing purpose.
Old 04-07-15, 12:52 PM   #4
audicoupeparts
Swapped pump over and started straight away (well, after me forgetting plug pump into tank cover top!
Spent half hour dissecting VAG aftermarket alarm and checking dizzy first
Just needs a wash before I dare it to fail an MOT
