Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Windscreen removal?
Old 09-01-15, 05:33 PM   #1
KAWASAKITRIPLE
Default Windscreen removal?
HI
i want to remove my own windscreen on my 87 coupe to do the a pillar rust repairs and prep for paint.
is this something i can do my self?
i pressume the rubber strip pulls out of the seal?
is it then a simple push out with your feet job or do i need to cut and replace the seal?
thanks in advance
damian.
KAWASAKITRIPLE is offline   Reply With Quote
Old 09-01-15, 05:51 PM   #2
rich.r
If you can get hold of a new rubber i would cut it
I tried to get a screen out and it broke using the feet method
Ohh and what kwak triple you got
Old 09-01-15, 05:56 PM   #3
sinbin5t
sinbin5t's Avatar
Yes do tell and put a photo on if poss
Old 09-01-15, 07:09 PM   #4
andya
andya's Avatar
http://www.ebay.co.uk/itm/NEW-AUDI-F...item3a9db4cd52
I would also cut it. Been there, also couldnt reuse the old seal.
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 09-01-15, 08:31 PM   #5
moonwatcher
moonwatcher's Avatar
Yep, I busted mine on my cq, If I was to have another go I'd use aluminium suction cups that you use on windows (glass windows not microsoft ), grip the screen. connect to a hoist/puller etc. put under slight tension, then try to release the rubber from the inside
Coupe Quattro 1985
Old 09-01-15, 09:12 PM   #6
lefthooker
Absolutely no need to use feet or cut rubbers. A couple of blunt flatblade screwdrivers and a bit of patience is all that's needed.
Old 09-01-15, 09:54 PM   #7
andya
andya's Avatar
I dont have patience
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 12-01-15, 01:36 PM   #8
KAWASAKITRIPLE
thanks for replys
i think i need to look out for a cheap windscreen seal... any s/hand ones?
my kwak was a kh250 which i had owned since 95 and sold to buy my audi coupe lol
Old 12-01-15, 05:38 PM   #9
rich.r
Originally Posted by KAWASAKITRIPLE View Post
thanks for replys
I rebuilt a KH250 as i couldnt afford one first time round in my yoof
Old 12-01-15, 07:15 PM   #10
sinbin5t
sinbin5t's Avatar
my kwak was a kh250
I had the S1-A 250 was a fair bit quicker than the KH but being earlier had drum brakes front and rear
Not even the Yam RD-250's could keep up with it
