Classic Audi » Technical » Mech/Tech » Interior » Audi "80" cab front door card removal.
Old 22-11-14, 10:24 PM   #1
flyingdragon248
Default Audi "80" cab front door card removal.
Hi can anyone on here tell me how to remove the door cards on a cab please? many thanks!
flyingdragon248 is offline   Reply With Quote
Old 23-11-14, 12:07 AM   #2
twr
quattro
from memory screws at door card ends upper safety catch /allen key screws in hidden holes at door close pull handle( access fom underside) remove switches at this point /card pulls up not out and rubber insulaters fall in to door when u lift door card /dont lift too high as mounting for cable door open handle on door card can snap .soory beer goggles at this hour if i forgot anything
twr is offline   Reply With Quote
Old 23-11-14, 12:17 AM   #3
twr
quattro
phillips screws in under pull handle surroud with L brackets and only back off 2 allen bolts for the handle surround
Old 23-11-14, 01:03 AM   #4
Targus
easiest way i've done loads before in the past
screw at front/rear top of door card
allen key at the front and then middle of the handle
hold onto the handle whilst its still fitted at the rear and pull the card up, then reach behind and unclip the cable and thats it from memory.
use a maccy d's straw on the popper to align it when refitting the card easily.
Targus is offline   Reply With Quote
Old 07-12-14, 06:11 PM   #5
flyingdragon248
thanks guys, worked a treat!
doors now wax oiled and window runners checked, and wood door cappings on.. happy days!
