Members: 43,033 | Total Threads: 40,083 | Total Posts: 471,018 Currently Active Users: 5678 (1 members and 5677 guests) Welcome to our newest member, Linksysjge |
Hi ,
Both windows on the passenger side are not working but the driver side ones are working fine . There doesn t appear to be any fuses for the windows. Any ideas greatly received before I attempt to dismantle the door cards and look at the motors / regulators. |
OCD member
It's been a while since I've had an Audi so all the following is from memory...
I believe the fuses are thermal trip and self resetting inside the relay. The first place I'd look for windows not working on a C3 is inside the door jamb bellows, starting with the drivers door... the wiring for the passenger side goes through here to the drivers door buttons. The way it's wired means that if the earth on the drivers door button for the passenger window down is open circuit, the button in the passenger door for down won't work either. The constant flexing of the wires eventually cracks the plastic wire insulation and allows damp to penetrate the copper strands eventually causing them to break. You'll need to peel back the wrap on the loom inside the bellows to check, replace the affected sections by piecing in a new section of wire. If you have a volt/continuity meter, you can check for continuity or voltage as required using the diagrams on my website here.
Current: 99 Subaru Forester S-Turbo Auto - interesting... but it's not a quattro 91 Reliant Scimitar SST 1400 - no.39 of 42... something for the weekend Previous: Two consecutive 1989 Audi 200 Quattro Turbo Avant, 1B 1990 Audi 100 SE Avant, NF 1986 Audi 100 CD Avant, KU 1987 VW Passat GL5E Estate, JS "Honorary" triple member of the 200,000+ Club ![]() Audi 200 in the UK (legacy website) Classic Audi member no: 258 Last edited by 5potnoodle; 11-09-14 at 12:49 AM. |
