Classic Audi » Classifieds section » Parts Wanted » Instrument Cluster: 8A0 919 035 S
Old 08-01-14, 11:54 AM   #1
1781cc
1781cc's Avatar
Default Instrument Cluster: 8A0 919 035 S
Anyone have one of these floating around? need to replace the one in my 2.8 Auto Cabby
thanks
Old 14-01-14, 10:01 AM   #2
1781cc
1781cc's Avatar
Bump for gauges with the right part numbers
Old 14-01-14, 05:12 PM   #3
audicoupeparts
I ll try take a look tonight, I have 2 v6 pods but not certain of part number
Old 14-01-14, 05:15 PM   #4
1781cc
1781cc's Avatar
thanks, that would be grand, mine is an auto, I am not sure that matters as I think the auto indicator bolts on and off with 2 screws.
key thing for me is matching part numbers and an untracked, working circuit board
Old 15-01-14, 06:24 AM   #5
The thing is simple - forget about that part number. I don't know why are you looking at it, I guess it's on some sticker on case, probably to reduce your chance to get one to almost zero. First compatibility thing - manufacturer. B3/B4 instrument cluster is like lego, as long as it is made by VDO. Between UN4 and VDO only trip comuter/autocheck/minicheck can be swapped, everything else is different. Second clock compatibility - since you have V6, rev counter should be from V6, unless you don't plan to use it, and speedometer from B4, with desired top speed - and if you only need PCB, then it has to be from car with rev counter.
