Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » ’93 Audi Cabriolet Boot Lid Alignment
Old 14-03-13, 07:27 PM   #1
Mattyboyblue
Mattyboyblue's Avatar
Default ’93 Audi Cabriolet Boot Lid Alignment
Hi,
When closed, the boot lid of my ’93 Cab appears to be sunk about 4mm too deep into the aperture leaving the trailing edges of the rear wings protruding like mini 1950s style fins.
The lid weighs a ton so I’m hardly surprised that it’s attempting to make its way through the car - but I’m not keen on the micro 1950s effect which spoils the look of a car with pretty much spot on panel gaps otherwise.
I’d be grateful for any advice on how to slightly raise the boot lid’s closed position please guys.
Mattyboyblue is offline   Reply With Quote
Old 14-03-13, 08:05 PM   #2
andydunn2
Ragtop Collector
Sounds like a bit of wear on your hinges. What I did with mine was slacken off the nuts slightly that attach the boot lid to the hinges and realign. You might need a new boot seal though if its been like that for a long time as it will compressed over the years and if you realign the hinges you may end up with. Gap between the seal and the boot kid.
"Earl" 1998 2.8 V6 Cabriolet
Old 14-03-13, 09:21 PM   #3
Mattyboyblue
Many thanks - I'll give that a go.
Old 15-03-13, 06:48 PM   #4
scottishaudi
if the boot lid is to low then all you have to do is slacken the bolts on the hinges to the boot lid, then make up some metal plates or just use washers between the boot lid and hinges that will lift your boot lid up 2 or 3 mm.
scottishaudi is offline   Reply With Quote
Old 15-03-13, 07:17 PM   #5
andydunn2
Ragtop Collector
If you do that you just need to be careful to ensure your boot lock engages properly that's all.
Old 23-07-13, 09:08 PM   #6
Mattyboyblue
Well having finally got round to giving it a go adjusting the hinges alone did the trick.
Tip: 13mm flexi-head ratchet ring spanner is made for the job.
Thanks Guys.
Old 24-07-13, 07:00 AM   #7
andydunn2
Ragtop Collector
Thanks Guys.
Happy days....
