Classic Audi » Technical » Mech/Tech » Engine » injector rubbers
Old 29-10-08, 06:27 PM   #1
Default injector rubbers
how do i change injector rubber grommets? i have taken out the injector. do i need to disconect the fuel line or will it slide up from the bottom of injector?
Old 29-10-08, 07:22 PM   #2
randall977
Mr Typ 43!
randall977's Avatar
If it's the later K-Jet type with a chrome end it should stretch over it and sit in the groove once pushed up the injector. I used a bit of oil to help it to sit in the plastic cup - most went in easily but one was an absolute pig???
Old 29-10-08, 07:26 PM   #3
thanks i will try that .all the rubbers are hard as nails
Old 29-10-08, 07:40 PM   #4
randall977
Mr Typ 43!
randall977's Avatar
Can you buy new ones? They are pretty tough - takes some pushing to get them on!
Old 29-10-08, 07:43 PM   #5
yes gsf sell them and the dealer sells them about 50 to 70p each they are same as the golf
Old 13-11-08, 05:18 AM   #6
spaarky
spaarky's Avatar
but if you're desperate, the rubber rocker stud o-rings in an aircooled vdub gasket set work just as well i.e. any good quality o-ring of the right size should do the job
spaarky is offline   Reply With Quote
injector o'rings jack1 Parts Wanted 4 29-01-10 03:37 PM
Wanted: UR/Coupe Windscreen Rubbers Dazmcc Parts Wanted 5 25-01-10 08:54 PM
100/A6/S4/S6 Door rubbers mortcars Parts For Sale 0 12-12-09 03:53 PM
best place to get injector seals?? laura80 General Chat 5 02-03-09 10:54 PM
Windscreen rubbers 80/90 T85 wanted martinjs Parts Wanted 1 15-09-08 09:15 PM
