Classic Audi » Technical » Mech/Tech » Engine » help with idle controll valve
Old 14-10-08, 07:22 PM   #1
Default help with idle controll valve
help with idle controll valve i have no power going to it.does anybody know where the power comes from.and where it is situated in the car.i think it comes from the enging brain
Old 14-10-08, 08:32 PM   #2
Engine code?
U think wrong ECU doesn't switch + ECU only switches ground. In case of SD/3A/NG, there is two additional fuses in fuse box, covered with "motor/moteur" plastic thing. One of them supplies power to ISV/Lambda heating/Fuel tank ventilation valves.
Old 14-10-08, 09:06 PM   #3
Hmmm audi 100 NG? almost same enginge as the ur ! as msh says check fuses
Old 14-10-08, 09:41 PM   #4
the engine code is ku071572 its a 2226 cc. the valve sits on top of the engine in a rubber grommet.i can power it from a seperate live and it works but not from the car wireing. the fuse box dont help, unless its part of another fuse powering something else?
Old 14-10-08, 10:27 PM   #5
So it's KU engine... Well, it's KV's twin, so it isn't as advanced as KV. Problem is - theese shematics I'm using is american, their engines was more advanced to comply emission laws I don't remember, was there seperate ISV control unit or wasnt... Anyway, when ignition is turned on, there must be +12v on one wire.
Are u sure u doesn't have any additional fuses in fuse box?
Old 15-10-08, 03:34 PM   #6
i have been told its part of the onbord computer which tells you the fuel ,distance, mpg, ect.which is on the little clock with the rev counter . still carn't find the control box.
Old 15-10-08, 06:41 PM   #7
Hahahah Trip computer is just thing that gives u some info, it doesn't do anything to engine
Old 17-10-08, 04:25 PM   #8
how mutch power goes to the idle controll valve is it volts or milli amps ?
Auxillary air valve on 5 cylinder - Idle problem Darron Edwards Engine 12 16-10-09 11:08 AM
Idle air control valve Micky Parts For Sale 0 18-09-09 09:22 PM
Idle Stabilization Valve Ringmaster Engine 2 21-08-09 03:45 PM
Low idle and a whine Alfashark Engine 2 29-03-09 04:10 PM
Idle stabilisation valve Micky Parts Wanted 17 03-10-08 07:41 PM
