Classic Audi » Technical » Mech/Tech » Transmission » Driveshaft hub nut query!
Old 02-07-11, 02:34 PM   #1
ian20v
ian20v's Avatar
Default Driveshaft hub nut query!
Realised i needed to drop the ur back on her wheels to get them driveshaft hub nuts undone 3 off nae bother, last one rounded on three sides so can't get socket on(theres always one!!) its a tight little spot,any ideas folks?As its got me stook and dont want to damage anything.Thanks
Old 02-07-11, 03:53 PM   #2
rich.r
find an old socket that can be driven on with a big feck off hammer warm said socket up with a plumbers tourch and hopefully it will undo
or do you have an impact gun as this will undo it as well
h t h rich
Old 02-07-11, 03:54 PM   #3
Phil Payne
Shoot - I've not had one of those yet!
As these cars age, of course, more and more nuts round themselves off just by rusting.
I use a Teng 3/4" drive 6-point flank drive socket and haven't had a problem yet. If you get REALLY desperate I'll mail it up but it HAS to come back quickly.
I'm in negotiation with a tool supplier here in Sheffield who has a special purpose 'get anything off' set in stock but wants too much moolah for it.
Old 02-07-11, 07:47 PM   #4
sam
yeah make sure you use single-hex socket and not multi-hex
Old 02-07-11, 11:24 PM   #5
Default Maybe?
Lots of WD40,aswell.Might help?
KARL.
Old 08-07-11, 02:55 PM   #6
martinws
What size is that nut?
I have a set of rounded nut taker offers that are like a socket with opposite threaded teeth inside it that bites into the nut to get it off. I cant remember how big a nut they can deal with though.
Have you heated it up?
Old 08-07-11, 10:23 PM   #7
ian20v
ian20v's Avatar
32mm and its still stuck, tried a bit of heat,another option is to try welding a nut on topwhat says you?
Old 09-07-11, 01:17 AM   #8
missfire
missfire's Avatar
a six foot bar and jump on it.
Old 09-07-11, 08:12 AM   #9
RetroAuto
Default Drill it!
I have had these before and the least painfull way is to drill down the side of the nut, it is quite a soft metal,
do one side first and use a small chisel to split the nut open,
if it's still not loose enough to undo, drill another hole in the nut opposite the first.
Old 09-07-11, 10:07 AM   #10
Phil Payne
I have had these before ...
As I said, I've never had one hang up. 280Nm is not that much on a 32mm nut - get a 3/4" drive six-point socket on it and the 1000Nm torque wrench - off it comes.
The problem is if some helpful sod has Loctited it. There should be a ring of white Loctite 1cm wide on the splines, but nothing on the nut.
And the nut, of course, is an ALWAYS RENEW item - they're actually triangular when you take them out of the packet.
But drilling and chiselling is a recommended way - Mr Chisel is often your best friend. As always - quality counts. Don't worry about the price of a good chisel - it WILL pay off.
