Classic Audi » Technical » Mech/Tech » Engine » Rattley top end.Valve clearancey sound.
Old 08-04-11, 10:52 PM   #1
SteveCat
SteveCat's Avatar
Default Rattley top end.Valve clearancey sound.
Well...the Coupe 16v has a tappety sound from the camcover for sure.
What is the set up under there? Shims and Hydraulic tappets??
Are shims easy and cheap enough to get hold of??
Mercedes E220 Sportline Coupe
Old 08-04-11, 11:56 PM   #2
Hydraulic tappets Steve, mine rattles sometimes from cold for the first mile or so
Old 09-04-11, 05:56 AM   #3
Just do an oil change then live with it.
Old 09-04-11, 06:51 AM   #4
Phil Payne
Banned
Hydraulic. Use at least 20W oil and a Mahle OC85 filter (with anti-drainback valve).
Old 09-04-11, 10:04 AM   #5
missfire
missfire's Avatar
so i need one of them also.....not a chinese unipart white can, like the one on it..?
there you go Mr Catman, i put that filter part no. into google and this came up!
http://www.isham-research.co.uk/quat...ine/15-20.html
Old 09-04-11, 10:23 AM   #6
Phil Payne
Banned
I hate it when that happens.
Old 09-04-11, 03:24 PM   #7
Roger Galvin
I think the OC85 has been deleted by Mahle, I've been using the OC47 equivalent supplied via Pete at quattro Corner for some months now.
Roger Galvin is offline   Reply With Quote
Old 09-04-11, 03:43 PM   #8
Phil Payne
Banned
Heh. So it seems, around a year ago:
http://www.l-auto.by/cms/images/sove...ent%20list.pdf
But I'm still getting OC 85s. Someone somewhere must have had a hell of a stock.
Old 09-04-11, 04:23 PM   #9
rickytractors
rickytractors's Avatar
My next door neighbor drains the engine oil and fill the sump with derv and runs it for 10 mins on tick over then drains it. Said this works on tappy hydraulic tappets, never tried it my self don't no what it would do to the seals.
rickytractors is offline   Reply With Quote
Old 09-04-11, 06:13 PM   #10
Hydraulic,don't use shims.
I have,the same problem.I'm going to try,a flush first.
If that doesn't work,I'll change the tappets.(After,checks.)
KARL.
