Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Camber shims for the rear?
Old 20-11-10, 08:54 AM   #1
doninphi
doninphi's Avatar
Default Camber shims for the rear?
Ive heard of them, but where do they go? Between the hub and the axle?
Anyone know where to get em? If so how much and what are my options for an audi 80 b2?
I'd like a touch on there to stop tyres rubbing etc (and before you say it no, I won't raise it up!! Lol
I make vinyl STICKERS! Pm me for any design you want...
doninphi is offline   Reply With Quote
Old 28-11-10, 05:40 PM   #2
16v80
16v80's Avatar
Hi.
Yes they go between the stub axle / hub and the axle.
You can get them, I have seen them in various degrees, ie -1, -2 and -3
I have forgotten from where tho,
The stub axle bolt spacing are the same as mk1,2 Golfs. have a look on ebay?
I had some made up that are 10mm thick with -1 degree, so now I have -2 as the rear beam has -1 from the factory.
I will have a look see if I can find them.
Ian
16v80 is offline   Reply With Quote
Old 28-11-10, 05:48 PM   #3
rich.r
ohh this is starting to look a bit "scene" here
saw this done to a caddy pick up with washers believe it or not
could you roll your arches or have you allready
Old 28-11-10, 06:10 PM   #4
doninphi
doninphi's Avatar
I already have! Don't want to 'pull' them as don't really want that look.
So mk1/2 one fit? If so cool as, I'll take a look, good to know they have -1 at the factory too, thanks!
Old 28-11-10, 06:13 PM   #5
doninphi
doninphi's Avatar
Searched eBay, eibach do some to go upto another -1.5 degrees, just short of £20 inc post, might get some for when I go rear discs...
