Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Anti roll bar rubber part number required.
Old 09-08-10, 12:48 PM   #1
Default Anti roll bar rubber part number required.
Im looking for the correct part number for the centrally mounted and clamped arb rubbers if anyone can help.
Audi supplied the following- 811 411 327B which is NOT correct.
The rubber theyve supplied has a tapered end to it which means it will not sit flat against the mounting position i have on mine.
Also the clamp will distort that particular rubber before its even attempted to clamp it up.
The rubber i would need has to have a flat backside to it so itl sits flat against the mount.
Bar diameter is 26mm.
edited to add: im a numpty. Would help if you knew what car eh? 1983 WR quattro front arb.
Old 09-08-10, 01:32 PM   #2
Cornholio
The mating face on the subframe is flat, right? I think it was the later subframe that had the indentation between the 2 bolt holes where the rubbber bush fits into..... If Audi can't supply the "flat faced" part any more, try the superflex part (contact Pete Reeves)
http://t85q.com/urTfa/Subgroups/frontaxle.html
Cornholio is offline   Reply With Quote
Old 09-08-10, 07:34 PM   #3
Phil Payne
Banned
Quite so. For a 1983 it should have been 857 411 327A.
Old 09-08-10, 07:46 PM   #4
Thanks fellas! Will get that one sorted out asap.
Old 09-08-10, 08:38 PM   #5
Pete Reeve
quattro corner have them,obsolete Audi
Pete Reeve is offline   Reply With Quote
Old 09-08-10, 09:08 PM   #6
How much?
