Members: 43,052 | Total Threads: 40,086 | Total Posts: 471,041 Currently Active Users: 3626 (6 members and 3620 guests) Welcome to our newest member, LeonelHip |
Hi everybody my quattro brakes are really soft, nearly going to the floor, Ive replace the bomb, master cylinder and all brake hoses pressure bled the syatem with a gunstons easy bleed, my next option seems to be the hi and low pressure switches on the assist regulator unit. (oh yes power steering is fine so I presume I have enough pressure)
Has anyone got any other ideas or where I can get these pesky pressure switches from Cheers jay |
you could try peter at quattro corner or Adam at AM Cars
it will be air , i used an easy bleed on mine and had the same result check the presure on the side of the easy bleed bottle to bleed it properly its quite low , the first time i just hooked up to the tyre and set about bleeding but it caurses micro bubbles in the fluid hence no presure , in the end i got a seely vacume bleeder from my local motor factors which works of a compresor and fits on the nipples and sucks the fluid through instead of forcing it i think it was £12 a couple of years back and i got a small compresor from b&q for £25 it works a treat and i ended up with the best break pedal i have ever had . here you go this is the one i have on ebay http://cgi.ebay.co.uk/Sealey-Vacuum-...item2a0632a809
john...
I may have a switch that you can have...I'll have a root around my shed next week matey. Daz
1981 ur quattro CA chassis LHD 1982 ur quattro CA chassis RHD 1986 ur quattro GA chassis - Alpine White 1986 ur quattro GA chassis - Graphite Black
Thankyou I am going to give the brakes another bleed and see what happens
Finallly found the fault the brake compensator valve (front/rear) had a tiny leak drawing in air got a second hand one from Vaudi that one leaked as well, does anyone know where I can get a new/second hand one from or even a overhaul kit? I only need this for the mot are they used on other Audi's?
Pete at quattro corner, i think you have to fit the later one now as the original is NLA
| Tags |
| ur 83 brakes poor |
