Classic Audi » Technical » Mech/Tech » Transmission » Gear box oil sealed for life
Old 07-03-20, 07:57 PM   #1
moonwatcher
moonwatcher's Avatar
Default Gear box oil sealed for life
I have the engine and gearbox out ready to go back in, question should I change the gear box oil?
I can't see it could do any harm?
Let sleeping dogs lie or not!
Coupe Quattro 1985
Old 07-03-20, 08:04 PM   #2
tractor Dave
Yes, for sure. Get it changed. The gearbox oil in my 1994 S2 looked horrible!
The diff oil in my Ur looked even worse! I've yet to change the Ur gearbox oil but it's on the jobs list.
You can get new fill/drain plugs on ebay and I recommend you change them while you are at it. You might find they are seized (mine were on the S2). I got around that by welding a bolt in the opening and the heat got it moving.
Old 07-03-20, 08:14 PM   #3
tractor Dave
https://www.ebay.co.uk/itm/VW-M24x1-...AAAOSwVFlULnpG
Old 09-03-20, 09:35 AM   #4
BackintheFold
BackintheFold's Avatar
As Dave says, yes. Change the oil.
With the box out it's easy, when it's back in the car its a nasty job, and much harder to deal with broken filler/drain plugs!
Old 09-03-20, 06:26 PM   #5
moonwatcher
Thanks for that info/advice, the plug in the quattro section is the same size, I've ordered two
Coupe Quattro 1985
